Problema scrittura bootloader Arduino UNO
Buongiorno a tutti.
Sto cercando di scrivere il bootloader in una UNO R3 utilizzando un'altra UNO R3 come programmatore.
Ho seguito la guida pubblicata in questo forum ma il processo termina comunque con un errore.
Di seguito posto il dump dell'errore:
Arduino:1.8.7 (Windows 10), Scheda:"Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x000000 (retrying)
Errore durante la scrittura del bootloader
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
Ho ricontrollato più volte le connessioni.
Da cosa può essere dovuto?
E' recuperabile la situazione?
Ti "ripeto" il consiglio di cercare su futura shop uno dei due programmatori avr pololu, si evitano molti "grattacapi".
Comunque il sospetto è che essendo l'arduino incriminato probabilmente non originale e in smd, sia proprio "rotto" il micro e non solo una questione di bootloader.
speedyant:
Azz...sei onnipresente! ;D
L'arduino è originale.
Proverò con quell'avr che mi consigli. Mi sembrava di aver capito che non fosse l'unica soluzione e mi sarebbe piaciuto capire se si potesse risolvere il problema in qualche altro modo e soprattutto se il problema non fosse solo il bootloader ma anche la scheda.
Per mie limitazioni, come ho scritto " di la" ho iniziato da poco, non sempre le informazioni sono chiare e lampanti.
Grazie comunque delle risposte che dai.
Il "metodo" arduino as isp viene considerato un ripiego. Il punto è che se riesci a programmare gli sketch, dovresti riuscire anche con il bootloader.
L'unico dubbio è che l'arduino incriminato, avendo il micro smd, non sia "esattamente" quello sulla uno "con i piedini"...
speedyant:
Il micro non è smd ma non escludo di aver scritto qualcosa che lo faccia pensare.
Il micro, in entrambi gli arduino, è montato sullo zoccolo. Per la precisione la sigla riportata su entrambi e ATMega328P-PU
Edit: Ho capito da dove esce il micro smd...le foto che ho postato erano prese da internet ed erano solo ad esempio dei tipi di connessioni che avevo usate nei tentativi di scrittura.
Se riuscivi a caricare gli sketch in "modalità" arduino as isp, il problema potrebbe anche essere qualcosa d'altro.
Non avendo mai utilizzato la modalità arduino as isp non ho idea di cosa possa essere.
