Problema visualización pantalla LCD Arduino UNO
Hola, soy nuevo en este mundo del Arduino y tengo un problema con la pantalla del LCD, creo que se debe a que pude haber quemado una patilla de los pines,no lo sé.
Se ve unos cuadrados de color blanco y las letras dentro, es apenas distinguible lo que dice (no pude adjuntar foto).
Aquí va el código:
//CONFIGURACION PINES Y LIBRERIA
#include <LiquidCrystal.h>
#define LED 4
#define BOTON 2
#define PIN1 7
#define PIN2 8
#define PIN3 9
#define PIN4 10
#define PIN5 11
#define PIN6 12
#define DELAYBOTON 300
//DEFINICION DE VARIABLES
LiquidCrystal lcd(PIN1,PIN2,PIN3,PIN4,PIN5,PIN6);
int cambio=0;
void setup(){
pinMode(PIN1,OUTPUT);
pinMode(PIN2,OUTPUT);
pinMode(PIN3,OUTPUT);
pinMode(PIN4,OUTPUT);
pinMode(PIN5,OUTPUT);
pinMode(PIN6,OUTPUT);
pinMode(LED,OUTPUT);
pinMode(BOTON,INPUT_PULLUP);
digitalWrite(LED,LOW);
lcd.begin(16,2);
lcd.print(“Estado LED”);
lcd.setCursor(0,1);
lcd.print(“Apagado”);
void loop(){
//COMPRUEBA SI PULSE BOTON
if(digitalRead(BOTON)==LOW){
if(cambio==0){
lcd.clear();
lcd.setCursor(0,1);
lcd.print(“PRENDIDO”);
cambio=1;
}else{
lcd.clear();
lcd.print("Estado Led: ");
lcd.setCursor(0,1);
cambio=0;
delay(DELAYBOTON);
//Prendo o apago led
if(cambio==1){
digitalWrite(LED,HIGH);
}else{
Translated:
Hello, I am new to this world of Arduino and I have a problem with the LCD screen, I think it is because I could have burned a pin of the pins, I do not know.
You can see some white squares and the letters inside, it is barely distinguishable what it says (I could not attach a photo).
Here is the code:
Adjust the contrast potentiometer.
groundFungus:
Translated:
Ahora se ve todo azul :c
Post a photo of your connections, please.
I tried your code with my Uno and a 16x2 LCD. It displays:
Estado LED
Apagado
So the code for the LCD works. Therefore there is a wiring problem. Is the R/W pin (LCD pin 5) connected to ground? It should be. Disconnect the potentiometer from pin 3 of the LCD and connect a 1K resistor from LCD pin 3 to ground. What do you see now?
Moderador:
Por favor, lee las normas del foro, de todo el foro no solo este.
Si posteas en el foro en inglés usas inglés y si alguien posteas en el foro en Español lo hace en nuestro idioma.
Asi que abstenerse de usar inglés.
To people that writes in english:
Please don´t use that language to post answers in this forum.
Además edita tu post inicial usando etiquetas para código.
En este foro respetamos las normas una por una.
Normas del foro.
