Hola, Gracias por adelantado.
Tengo una target SD 128M pruebo el ejemplo read/write i me funciono una sola vez, i ahora me aparece el siguiente error:
Initializing SD card...initialization failed!
ayer con otro ejemplo de la Sd me funcione pero no consigo k me vuelva a funcionar. La SD va isertada dentro de una Tft 2,8" Toush shield V2 col.locada directamente encima del arduino i los pins son los siguientes:
D4 :TF_CS, SD card select input pin
D5 :TF_CS,TFT Chip select input pin
D6:TF_D/C, TFT Data/Command control pin
D7: BACKLIGHT,TFTbacklight control pin
Pins used for SPI INTERFACE
D10: SPI Chip Select
D11: SPI Data pin
D12: SPI serial clok pin
A0,A1,A2,A3 Touch Screen ...
El programa es el de la libreria i es el siguiente:
SD card read/write
This example shows how to read and write data to and from an SD card file
The circuit:
- SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SD.h>
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("testing 1, 2, 3.");
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// re-open the file for reading:
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
// nothing happens after setup
