Problème Arduino SIM800L PIN RESET
Bonjour,
j’utilise Arduino Uno pour recevoir des SMS avec le module SIM800L.
J’utilise la librairie Sim800L-Arduino-Library-revised : https://github.com/VittorioEsposito/Sim800L-Arduino-Library-revised
Le code et le branchement que j’utilise :
 *        _____________________________
 *       |  ARDUINO UNO >>>   Sim800L  |
 *        GND      >>>   GND
 *        RX  10       >>>   TX
 *        TX  11       >>>   RX
 *        RESET 2       >>>   RST
#include <Sim800L.h>
#include <SoftwareSerial.h>
#define RX  10
#define TX  11
#define RESET 2
Sim800L GSM(RX, TX, RESET);
String textSms, numberSms;
uint8_t index1;
bool error;
void setup(){
    Serial.begin(9600); // only for debug the results .
    GSM.begin(9600); // initializate the library.
    Serial.println("Before reset");
    GSM.reset();
    Serial.println("After reset");
    //don't forget to catch the return of the function delAllSms!
    error=GSM.delAllSms(); //clean memory of sms;
void loop(){
    textSms=GSM.readSms(1); //read the first sms
    if (textSms.indexOf("OK")!=-1) //first we need to know if the messege is correct. NOT an ERROR
        if (textSms.length() > 7)  // optional you can avoid SMS empty
                numberSms=GSM.getNumberSms(1);  // Here you have the number
                //for debugin
                Serial.println(numberSms);
                textSms.toUpperCase();  // set all char to mayus ;)
                if (textSms.indexOf("TURNON")!=-1){
                    Serial.println("LED TURN ON");
                else if (textSms.indexOf("TURNOFF")!=-1){
                    Serial.println("LED TURN OFF");
                else{
                    Serial.println("Not Compatible ...sorry.. :D");
            GSM.delAllSms(); //do only if the message is not empty,in other case is not necesary
             //delete all sms..so when receive a new sms always will be in first position
Le problème:
  • Si je relie le PIN RST du module SIM800L au PIN 2 de l’Arduino, le module ne clignote plus (ne marche donc pas)
  • Si j’enlève ce branchement, le module recommence à clignoter.
    Le moniteur série affiche seulement “Before reset”.
    Je crois que c’est la méthode reset() qui pose problème.
    voici son code (tiré de la libraire):
void Sim800L::reset()
    if (LED_FLAG) digitalWrite(LED_PIN,1);
    digitalWrite(RESET_PIN,1);
    digitalWrite(RESET_PIN,0);
    // wait for the module response
    this->SoftwareSerial::print(F("AT\r\n"));
    while (_readSerial().indexOf("OK")==-1 )
    //wait for sms ready
    while (_readSerial().indexOf("SMS")==-1 );
    if (LED_FLAG) digitalWrite(LED_PIN,0);
Merci de votre aide.
Bonsoir
Essayer en inversant la séquence de niveaux logiques sur le Reset
d'abord 0 pour activer le Reset puis 1 pour quitter le Reset
Le Reset d'un SIM800L est actif à l'état bas
Bonjour
j'ai finalement trouver un bout de code avec uniquement les commandes AT et cela marche bien.
Merci quand même.
