bonjour groupe
voici j'ai complile mon programe pour mon arduinio uno et tout fonction bien mais j'aimerais le transfere sur mon NodeMCU (esp-12e) mais quand je complile le meme programe il me fais des erruer
voici mon code et les erreur
si quelqu'un peux me donner une piste de solution
merci
#define PIN 4
#define PIN 3
#define HIGH1
#define LOW0
Adafruit_NeoPixel strip150 = Adafruit_NeoPixel (5 , PIN 3 ,NEO_GRB + NEO_KHZ800 );
Adafruit_NeoPixel strip100 = Adafruit_NeoPixel ( 12 , PIN 4 ,NEO_GRB + NEO_KHZ800 );
const int offPin = 10; // the number of the pushbutton pin
const int whitePin = 13;
const int greenPin = 6;
const int redPin = 8;
const int bluePin = 5;
// variables will change:
int offState = 0; // variable for reading the pushbutton status
int whiteState = 0;
int greenState = 0;
int redState = 0;
int blueState = 0;
int pixelSpeed = 10;
strip150.begin();
strip100.begin();
strip150.show();
strip100.show();
pinMode(offPin, INPUT_PULLUP);
pinMode(whitePin, INPUT_PULLUP);
pinMode(greenPin, INPUT_PULLUP);
pinMode(bluePin, INPUT_PULLUP);
pinMode(redPin, INPUT_PULLUP);
pinMode(4, OUTPUT);
pinMode(3, OUTPUT);
// Some example procedures showing how to display to the pixels:
whiteState = digitalRead(whitePin);
offState = digitalRead(offPin);
greenState = digitalRead (greenPin);
blueState = digitalRead (bluePin);
redState = digitalRead (redPin);
if (greenState == LOW || redState == LOW || blueState == LOW) {
colorWipe(strip150.Color(255 * (1 - redState), 255 * (1 - greenState), 255 * (1 - blueState)), pixelSpeed);
colorWipe(strip100.Color(255 * (1 - redState), 255 * (1 - greenState), 255 * (1 - blueState)), pixelSpeed);// RGB
else {
if (whiteState == LOW) {
colorWipe(strip150.Color(255, 255, 255), pixelSpeed);
colorWipe(strip100.Color(255, 255, 255), pixelSpeed);// WHITE
if (offState == LOW) {
colorWipe(strip150.Color(0, 0, 0), pixelSpeed);
colorWipe(strip100.Color(0, 0, 0), pixelSpeed);// BLACK
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip150.numPixels(); i++)
for(uint16_t i=0; i<strip100.numPixels(); i++){
strip150.setPixelColor(i, c);
strip100.setPixelColor(i, c);
strip150.show();
strip100.show();
delay(wait);
et mes erreurs sont
projet_led_bouton_qui_fonctionne_avec_modif_du_forum\projet_led_bouton_qui_fonctionne_avec_modif_du_forum.ino:4: warning: "PIN" redefined
4 | #define PIN 3
projet_led_bouton_qui_fonctionne_avec_modif_du_forum\projet_led_bouton_qui_fonctionne_avec_modif_du_forum.ino:3: note: this is the location of the previous definition
3 | #define PIN 4
projet_led_bouton_qui_fonctionne_avec_modif_du_forum\projet_led_bouton_qui_fonctionne_avec_modif_du_forum.ino:9:48: error: expected primary-expression before '(' token
9 | Adafruit_NeoPixel strip150 = Adafruit_NeoPixel (5 , PIN 3 ,NEO_GRB + NEO_KHZ800 );
projet_led_bouton_qui_fonctionne_avec_modif_du_forum\projet_led_bouton_qui_fonctionne_avec_modif_du_forum.ino:9:57: error: expected ')' before numeric constant
projet_led_bouton_qui_fonctionne_avec_modif_du_forum\projet_led_bouton_qui_fonctionne_avec_modif_du_forum.ino:10:48: error: expected primary-expression before '(' token
10 | Adafruit_NeoPixel strip100 = Adafruit_NeoPixel ( 12 , PIN 4 ,NEO_GRB + NEO_KHZ800 );
projet_led_bouton_qui_fonctionne_avec_modif_du_forum\projet_led_bouton_qui_fonctionne_avec_modif_du_forum.ino:10:59: error: expected ')' before numeric constant
exit status 1
Compilation error: expected primary-expression before '(' token
