Bonjour à tous !
Je vais vous exposer mon problème mais avant cela, voici mon matériel:
- Carte Arduino UNO
- Shield GPS (Adafruit Ultimate GPS)
Après m'être procuré ce Shield GPS, j'ai suivi la doc (cf. documentation ici). Jusqu'à ce moment là (page 18 pour les plus perspicaces d'entre vous ):
J'ai donc directement ouvert le code d'exemple que voici:
// Test code for Adafruit GPS modules using MTK3329/MTK3339 driver
// This code just echos whatever is coming from the GPS unit to the
// serial monitor, handy for debugging!
// Tested and works great with the Adafruit Ultimate GPS module
// using MTK33x9 chipset
// ------> http://www.adafruit.com/products/746
// Pick one up today at the Adafruit electronics shop
// and help support open source hardware & software! -ada
//This code is intended for use with Arduino Leonardo and other ATmega32U4-based Arduinos
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
// Connect the GPS Power pin to 5V
// Connect the GPS Ground pin to ground
// If using software serial (sketch example default):
// Connect the GPS TX (transmit) pin to Digital 8
// Connect the GPS RX (receive) pin to Digital 7
// If using hardware serial:
// Connect the GPS TX (transmit) pin to Arduino RX1 (Digital 0)
// Connect the GPS RX (receive) pin to matching TX1 (Digital 1)
// If using software serial, keep these lines enabled
// (you can change the pin numbers to match your wiring):
SoftwareSerial mySerial(8, 7);
// If using hardware serial, comment
// out the above two lines and enable these two lines instead:
//HardwareSerial mySerial = Serial1;
#define PMTK_SET_NMEA_UPDATE_1HZ "$PMTK220,1000*1F"
#define PMTK_SET_NMEA_UPDATE_5HZ "$PMTK220,200*2C"
#define PMTK_SET_NMEA_UPDATE_10HZ "$PMTK220,100*2F"
// turn on only the second sentence (GPRMC)
#define PMTK_SET_NMEA_OUTPUT_RMCONLY "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29"
// turn on GPRMC and GGA
#define PMTK_SET_NMEA_OUTPUT_RMCGGA "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
// turn on ALL THE DATA
#define PMTK_SET_NMEA_OUTPUT_ALLDATA "$PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
// turn off output
#define PMTK_SET_NMEA_OUTPUT_OFF "$PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
#define PMTK_Q_RELEASE "$PMTK605*31"
while (!Serial); // wait for leo to be ready
Serial.begin(57600); // this baud rate doesn't actually matter!
mySerial.begin(9600);
delay(2000);
Serial.println("Get version!");
mySerial.println(PMTK_Q_RELEASE);
// you can send various commands to get it started
//mySerial.println(PMTK_SET_NMEA_OUTPUT_RMCGGA);
mySerial.println(PMTK_SET_NMEA_OUTPUT_ALLDATA);
mySerial.println(PMTK_SET_NMEA_UPDATE_1HZ);
if (Serial.available()) {
char c = Serial.read();
Serial.write(c);
mySerial.write(c);
if (mySerial.available()) {
char c = mySerial.read();
Serial.write(c);
Puis après le transfert dans ma carte Arduino, je m'attendais à voir défiler un type de trame mais au lieu de ça, voici le résultat:
Je fais donc appelle à vous pour savoir pourquoi, je ne vois rien qui défile dans le moniteur série
Je tiens à préciser que je ne suis pas ultra familier avec Arduino, donc s'il vous plait, soyez indulgents
Merci de votre futur aide et d'avoir pris du temps pour lire ce post.
