probleme avec un code copier coller
Bonjour, de retour avec un nouveau projet j'ai besoin de votre aide. Voila ma source: https://code.google.com/p/point-de-spawn/source/browse/point_de_spawn_beta.ino
donc mon probleme quand je copie colle le code (qui a priori fonctionne chez le type qui la poster): Arduino: 1.5.4 (Windows 7), Board: "Arduino Uno"
sketch_oct05a.ino: In function 'void setup()': sketch_oct05a:92: error: 'PCD8544' does not name a type sketch_oct05a:94: error: a function-definition is not allowed here before '{' token sketch_oct05a:112: error: a function-definition is not allowed here before '{' token sketch_oct05a:132: error: a function-definition is not allowed here before '{' token sketch_oct05a:256: error: expected `}' at end of input
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
Merci de votre aide. A+
