Euh, windows 7 64bits, le programme est le suivant (je ne l'ai pas lu, dans le tuto on demande de le mettre sur la carte, c'est ce que je me contente de faire):
#include <TimerOne.h>
boolean firstRun = true; // Used for one-run-only stuffs;
//First pin being used for floppies, and the last pin. Used for looping over all pins.
const byte FIRST_PIN = 2;
const byte PIN_MAX = 17;
#define RESOLUTION 40 //Microsecond resolution for notes
/*NOTE: Many of the arrays below contain unused indexes. This is
to prevent the Arduino from having to convert a pin input to an alternate
array index and save as many cycles as possible. In other words information
for pin 2 will be stored in index 2, and information for pin 4 will be
stored in index 4.*/
/*An array of maximum track positions for each step-control pin. Even pins
are used for control, so only even numbers need a value here. 3.5" Floppies have
80 tracks, 5.25" have 50. These should be doubled, because each tick is now
half a position (use 158 and 98).
byte MAX_POSITION[] = {
0,0,158,0,158,0,158,0,158,0,158,0,158,0,158,0,158,0};
//Array to track the current position of each floppy head. (Only even indexes (i.e. 2,4,6...) are used)
byte currentPosition[] = {
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
/*Array to keep track of state of each pin. Even indexes track the control-pins for toggle purposes. Odd indexes
track direction-pins. LOW = forward, HIGH=reverse
int currentState[] = {
0,0,LOW,LOW,LOW,LOW,LOW,LOW,LOW,LOW,LOW,LOW,LOW,LOW,LOW,LOW,LOW,LOW
//Current period assigned to each pin. 0 = off. Each period is of the length specified by the RESOLUTION
//variable above. i.e. A period of 10 is (RESOLUTION x 10) microseconds long.
unsigned int currentPeriod[] = {
//Current tick
unsigned int currentTick[] = {
//Setup pins (Even-odd pairs for step control and direction
void setup(){
pinMode(13, OUTPUT);// Pin 13 has an LED connected on most Arduino boards
pinMode(2, OUTPUT); // Step control 1
pinMode(3, OUTPUT); // Direction 1
pinMode(4, OUTPUT); // Step control 2
pinMode(5, OUTPUT); // Direction 2
pinMode(6, OUTPUT); // Step control 3
pinMode(7, OUTPUT); // Direction 3
pinMode(8, OUTPUT); // Step control 4
pinMode(9, OUTPUT); // Direction 4
pinMode(10, OUTPUT); // Step control 5
pinMode(11, OUTPUT); // Direction 5
pinMode(12, OUTPUT); // Step control 6
pinMode(13, OUTPUT); // Direction 6
pinMode(14, OUTPUT); // Step control 7
pinMode(15, OUTPUT); // Direction 7
pinMode(16, OUTPUT); // Step control 8
pinMode(17, OUTPUT); // Direction 8
Timer1.initialize(RESOLUTION); // Set up a timer at the defined resolution
Timer1.attachInterrupt(tick); // Attach the tick function
void loop(){
//The first loop, reset all the drives, and wait 2 seconds...
if (firstRun)
firstRun = false;
resetAll();
delay(2000);
//Only read if we have
if (Serial.available() > 2){
//Watch for special 100-message to reset the drives
if (Serial.peek() == 100) {
resetAll();
//Flush any remaining messages.
while(Serial.available() > 0){
Serial.read();
else{
currentPeriod[Serial.read()] = (Serial.read() << 8) | Serial.read();
Called by the timer inturrupt at the specified resolution.
void tick()
If there is a period set for control pin 2, count the number of
ticks that pass, and toggle the pin if the current period is reached.
if (currentPeriod[2]>0){
currentTick[2]++;
if (currentTick[2] >= currentPeriod[2]){
togglePin(2,3);
currentTick[2]=0;
if (currentPeriod[4]>0){
currentTick[4]++;
if (currentTick[4] >= currentPeriod[4]){
togglePin(4,5);
currentTick[4]=0;
if (currentPeriod[6]>0){
currentTick[6]++;
if (currentTick[6] >= currentPeriod[6]){
togglePin(6,7);
currentTick[6]=0;
if (currentPeriod[8]>0){
currentTick[8]++;
if (currentTick[8] >= currentPeriod[8]){
togglePin(8,9);
currentTick[8]=0;
if (currentPeriod[10]>0){
currentTick[10]++;
if (currentTick[10] >= currentPeriod[10]){
togglePin(10,11);
currentTick[10]=0;
if (currentPeriod[12]>0){
currentTick[12]++;
if (currentTick[12] >= currentPeriod[12]){
togglePin(12,13);
currentTick[12]=0;
if (currentPeriod[14]>0){
currentTick[14]++;
if (currentTick[14] >= currentPeriod[14]){
togglePin(14,15);
currentTick[14]=0;
if (currentPeriod[16]>0){
currentTick[16]++;
if (currentTick[16] >= currentPeriod[16]){
togglePin(16,17);
currentTick[16]=0;
void togglePin(byte pin, byte direction_pin) {
//Switch directions if end has been reached
if (currentPosition[pin] >= MAX_POSITION[pin]) {
currentState[direction_pin] = HIGH;
digitalWrite(direction_pin,HIGH);
else if (currentPosition[pin] <= 0) {
currentState[direction_pin] = LOW;
digitalWrite(direction_pin,LOW);
//Update currentPosition
if (currentState[direction_pin] == HIGH){
currentPosition[pin]--;
else {
currentPosition[pin]++;
//Pulse the control pin
digitalWrite(pin,currentState[pin]);
currentState[pin] = ~currentState[pin];
//// UTILITY FUNCTIONS
//Not used now, but good for debugging...
void blinkLED(){
digitalWrite(13, HIGH); // set the LED on
delay(250); // wait for a second
digitalWrite(13, LOW);
//For a given controller pin, runs the read-head all the way back to 0
void reset(byte pin)
digitalWrite(pin+1,HIGH); // Go in reverse
for (byte s=0;s<MAX_POSITION[pin];s+=2){ //Half max because we're stepping directly (no toggle)
digitalWrite(pin,HIGH);
digitalWrite(pin,LOW);
delay(5);
currentPosition[pin] = 0; // We're reset.
digitalWrite(pin+1,LOW);
currentPosition[pin+1] = 0; // Ready to go forward.
//Resets all the pins
void resetAll(){
// Old one-at-a-time reset
//for (byte p=FIRST_PIN;p<=PIN_MAX;p+=2){
// reset(p);
// New all-at-once reset
for (byte s=0;s<80;s++){ // For max drive's position
digitalWrite(p+1,HIGH); // Go in reverse
digitalWrite(p,HIGH);
digitalWrite(p,LOW);
delay(5);
currentPosition[p] = 0; // We're reset.
digitalWrite(p+1,LOW);
currentState[p+1] = 0; // Ready to go forward.
Et comme j'ai un nouveau pc, je vais tester sur l'ancien voir si j'ai le même problème.
Dans le gestionnaire des périphériques, le com1 est reconnu comme cela:
Emplacement: sur Intel(R) Z68 Express Chipset Family LPC Interface Controller - 1C44
Voilà voilà
