bonjour ,
je rencontre un problème lors de la vérification du programme, j'ai installé et désinstallé plusieurs fois VSCODE + platformIO toujours le même message d'erreur lors de la vérification, je vous joins le message si quelqu'un pourrais me porter secours :
Processing uno (platform: atmelavr; board: uno; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.4.0) > Arduino Uno
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 31.50KB Flash
DEBUG: Current (avr-stub) On-board (avr-stub, simavr)
PACKAGES:
- framework-arduino-avr 5.1.0
- toolchain-atmelavr 1.70300.191015 (7.3.0)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 5 compatible libraries
Scanning dependencies...
No dependencies
Building in release mode
Compiling .pio\build\uno\src\main.cpp.o
Compiling .pio\build\uno\FrameworkArduino\CDC.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial.cpp.o
avr-g++: fatal error: no input files
compilation terminated.
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial0.cpp.o
Le chemin d'acc\x8as sp\x82cifi\x82 est introuvable.
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial1.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial2.cpp.o
Compiling .pio\build\uno\FrameworkArduino\HardwareSerial3.cpp.o
*** [.pio\build\uno\src\main.cpp.o] Error 1
Compiling .pio\build\uno\FrameworkArduino\IPAddress.cpp.o
*** [.pio\build\uno\FrameworkArduino\CDC.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial0.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial1.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial2.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\HardwareSerial3.cpp.o] Error 1
*** [.pio\build\uno\FrameworkArduino\IPAddress.cpp.o] Error 1
======================================================== [FAILED] Took 0.81 seconds ========================================================
The terminal process "C:\Users\D&v\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'uno'" terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
#include <Arduino.h>
int led=13; // Définition des variables
int temp=1000;
pinMode(led, OUTPUT); //Définition de la variable led en OUTPUT
digitalWrite(led,1); //# Code .....
delay(temp);
digitalWrite(led,0);
delay(temp);
* Blink
* Turns on an LED on for one second,
* then off for one second, repeatedly.
// initialize LED digital pin as an output.
pinMode(LED_BUILTIN, OUTPUT);
// turn the LED on (HIGH is the voltage level)
digitalWrite(LED_BUILTIN, HIGH);
// wait for a second
// turn the LED off by making the voltage LOW
digitalWrite(LED_BUILTIN, LOW);
platform.ini :
; PlatformIO Project Configuration File
; Build options: build flags, source filter, extra scripting
; Upload options: custom port, speed and extra flags
; Library options: dependencies, extra library storages
; Please visit documentation for the other options and examples
; http://docs.platformio.org/page/projectconf.html
[env:uno]
platform = atmelavr
framework = arduino
board = uno
lors du build :
> Executing task: C:\Users\D&v\.platformio\penv\Scripts\platformio.exe run <
Processing uno (platform: atmelavr; framework: arduino; board: uno)
------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PACKAGES:
No dependencies
Compiling .pio\build\uno\src\Blink.cpp.o
Archiving .pio\build\uno\libFrameworkArduinoVariant.a
*** [.pio\build\uno\src\Blink.cpp.o] Error 1
=================================================================== [FAILED] Took 1.84 seconds ===================================================================The terminal process "C:\Users\D&v\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
voila je retourve toujours le meme probleme
du avr-g++: fatal error: no input files
