Problème code - Help !
Bonjour !
J'ai ce code mais ça ne marche qu'une fois sur deux, est-ce qu'il y a un problème avec le reste automatique ? Pouvez-vous m'aider ?
Merci !
#include <Password.h> //http://playground.arduino.cc/uploads/Code/Password.zip //tells to use password library
#include <Keypad.h> //http://www.arduino.cc/playground/uploads/Code/Keypad.zip  //tells to use keypad library
Password password = Password( "1234" ); //password to unlock, can be changed
const byte ROWS = 4; // Four rows
const byte COLS = 3; // columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 9, 8, 7, 6 };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 5, 4, 3 };
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
 Serial.write(254);
 Serial.write(0x01);
 delay(200);
 pinMode(11, OUTPUT);  //green light
 pinMode(12, OUTPUT);  //red light
 pinMode(13, OUTPUT); // electro
 keypad.addEventListener(keypadEvent); //add an event listener for this keypad
void loop(){
 digitalWrite(13, HIGH);
 keypad.getKey();
 //take care of some special events
 void keypadEvent(KeypadEvent eKey){
 switch (keypad.getState()){
 case PRESSED:
 Serial.print("Enter:");
 Serial.println(eKey);
 delay(10);
 switch (eKey){
   case '*': checkPassword(); delay(1); break;
   case '#': password.reset(); delay(1); break;
    default: password.append(eKey); delay(1);
void checkPassword(){
if (password.evaluate()){  //if password is right open
   Serial.println("Accepted");
   digitalWrite(13, LOW);//Désarme l'electro-aimant
   digitalWrite(11, HIGH);//allume led verte
   delay(2000); //Temps qui peut être changé
   digitalWrite(11, LOW);// éteint led verte
}else{
   Serial.println("Denied"); //if passwords wrong keep locked
   delay(1000); //
   password.reset(); // faire une mise à zéro et attends mot de passe
   digitalWrite(12, HIGH); //led rouge allumée
   delay(2000); //wait 5 seconds
   digitalWrite(12, LOW);//led rouge éteinte
bonjour,
édite ton post et utilise la balise code </>
le code n'est pas entier en plus
et en clair, ca donne quoi?
Bonjour,
Merci pour ta réponse !
J'ai copié le code en entier et utilisé les balises...mais j'ai l'impression que l'affichage ne les prend pas en compte :confused:
Il s'agit d'une séquence de 4 interrupteurs à actionner dans un ordre donné (ici 1, 2, 3, 4) pour débloquer un électroaimant. Voici ce qu'il se passe avec ce code :
  1. Lorsque j'actionne les 4 interrupteurs dans le bon ordre, l'électroaimant s'ouvre, c'est ok (Moniteur série : ACCEPTED)
  2. Puis, lorsque j'actionne à nouveau ces 4 interrupteurs, l'EM ne s'ouvre pas (Moniteur série : DENIED)
  3. Ensuite, lorsque je ré-essaie une 3ème fois, ça fonctionne (Moniteur série : ACCEPTED)
  4. Puis la 4ème fois ça ne fonctionne plus (DENIED)
    et ainsi de suite...
JujuBile:
Bonjour,
Les balises de code c'est
[code]et [/code]
Au lieu de les écrire explicitement tu peux aussi utiliser la méthode décrite ici.
Merci bien ! :slight_smile: A présent c'est ok, j'ai mis en format code.
Est-ce que quelqu'un voit le problème ?
le code est pour un keypad
tu utilise quoi comme interrupteurs?
tu valide comment?
