bonjour,
j'ai un problème de compilation que je n'arrive pas à résoudre :
C:\Users\frederic\AppData\Local\Temp\cceBDM42.ltrans0.ltrans.o: In function `main':
cceBDM42.ltrans0.o:(.text.startup+0x280): undefined reference to `SPIClass::begin()'
collect2.exe: error: ld returned 1 exit status
quelqu'un peut m'aider…. carte utilisée : Arduino nano
D'avance merci.
#include <RFID.h>
#include <MFRC522.h>
#include <SPI.h>
#define SAD 10
#define RST 5
MFRC522 nfc(SAD, RST);
/*Modified by: BehindTheSciences.com */
#include <LiquidCrystal.h>
//#define RS 12
#define RS 6
#define RW 2
//#define EN 11
#define EN 4
//#define VO 13
#define VO 5
#define D4 7
#define D5 8
//#define D6 9
#define D6 A0
//#define D7 10
#define D7 3
int i = 1;
// initialize the library with the numbers of the interface pins
//LiquidCrystal lcd(12, 11, 7, 8, 9, 10);
LiquidCrystal lcd(RS, EN, D4, D5, D6, D7);
/*Initialisation of the LCD */
pinMode(D4, OUTPUT);
pinMode(D5, OUTPUT);
pinMode(D6, OUTPUT);
pinMode(D7, OUTPUT);
pinMode(EN, OUTPUT);
digitalWrite(EN, HIGH);
pinMode(RS, OUTPUT);
digitalWrite(RS, LOW);
pinMode(VO, OUTPUT);
digitalWrite(VO, LOW);
pinMode(RW, OUTPUT);
digitalWrite(RW, LOW);
delay(20);
digitalWrite(D7, LOW);
digitalWrite(D6, LOW);
digitalWrite(D5, HIGH);
digitalWrite(D4, HIGH);
delay(10);
digitalWrite(D4, LOW);
digitalWrite(D7, HIGH);
digitalWrite(D6, HIGH);
digitalWrite(D5, LOW);
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.setCursor(3, 0);
lcd.print("Behind The");
lcd.setCursor(4, 1);
lcd.print("Sciences");
delay(30);
lcd.clear();
lcd.setCursor(1, 0);
SPI.begin();
// Read a fast as possible. There is a limit for how long we are
// allowed to read from the tags.
Serial.println("Looking for MFRC522.");
nfc.begin();
// Get the firmware version of the RFID chip
byte version = nfc.getFirmwareVersion();
if (! version) {
Serial.print("Didn't find MFRC522 board.");
while(1); //halt
Serial.print("Found chip MFRC522 ");
Serial.print("Firmware ver. 0x");
Serial.print(version, HEX);
Serial.println(".");
byte keyA[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, };
byte keyB[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, };
byte status;
byte data[MAX_LEN];
byte serial[5];
int i, j, pos;
// Send a general request out into the aether. If there is a tag in
// the area it will respond and the status will be MI_OK.
status = nfc.requestTag(MF1_REQIDL, data);
if (status == MI_OK) {
Serial.println("Tag detected.");
Serial.print("Type: ");
Serial.print(data[0], HEX);
Serial.print(", ");
Serial.println(data[1], HEX);
// calculate the anti-collision value for the currently detected
// tag and write the serial into the data array.
status = nfc.antiCollision(data);
memcpy(serial, data, 5);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("SerialNo:");
Serial.println("The serial nb of the tag is:");
for (i = 0; i < 3; i++) {
//lcd.setCursor(i, 0);
lcd.print(serial[i],HEX);
Serial.print(serial[i], HEX);
Serial.print(", ");
Serial.println(serial[3], HEX);
lcd.print(serial[3], HEX);
// Select the tag that we want to talk to. If we don't do this the
// chip does not know which tag it should talk if there should be
// any other tags in the area..
nfc.selectTag(serial);
// Assuming that there are only 64 blocks of memory in this chip.
for (i = 0; i < 64; i++) {
// Try to authenticate each block first with the A key.
status = nfc.authenticate(MF1_AUTHENT1A, i, keyA, serial);
Serial.print("Authenticated block nb. 0x");
Serial.print(i, HEX);
Serial.println(" with key A.");
// Reading block i from the tag into data.
status = nfc.readFromTag(i, data);
// If there was no error when reading; print all the hex
// values in the data.
for (j = 0; j < 15; j++) {
Serial.print(data[j], HEX);
Serial.print(", ");
Serial.println(data[15], HEX);
Serial.println("Read failed.");
// If we could not authenticate with the A key, we will try
// the B key.
status = nfc.authenticate(MF1_AUTHENT1B, i, keyB, serial);
Serial.println(" with key B.");
Serial.print(", ");
Serial.print("Access denied at block nb. 0x");
Serial.println(i, HEX);
// Stop the tag and get ready for reading a new tag.
nfc.haltTag();
delay(2000);
