Problème de téléversement / programmer is not responding [RESOLU]
Effectivement, ca change tout !
Ca semble bien programmer l'ATmega, j'ai le rapport suivant (je n'ai mis que la deuxième moitié):
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM12
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\Ludo\AppData\Local\Temp\arduino_build_587003/Blink.ino.hex"
avrdude: writing flash (938 bytes):
Writing | ################################################## | 100% 1.11s
avrdude: 938 bytes of flash written
avrdude: verifying flash memory against C:\Users\Ludo\AppData\Local\Temp\arduino_build_587003/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\Ludo\AppData\Local\Temp\arduino_build_587003/Blink.ino.hex:
avrdude: input file C:\Users\Ludo\AppData\Local\Temp\arduino_build_587003/Blink.ino.hex contains 938 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.63s
avrdude: verifying ...
avrdude: 938 bytes of flash verified
avrdude done.  Thank you.
Mais finalement, il m'est impossible de faire clignoter une led. Elle fonctionne correctement (et est dans le bon sens), anode vers le pin 13 derrière une résistance de 470ohms, cathode sur la masse.
Comment être certain que l'ATmega est bien chargé !!?
Merci encore
