Problème de téléversement sur imprimante anet A8
Bonjour,
J'aimerai mettre un jour mon fireware de ma carte de mon imprimante, le seule problème message d'erreur :
Arduino : 1.8.3 (Mac OS X), Carte : "Anet V1.0"
Linking everything together...
"/Users/flo/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega1284p  -o "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/Marlin.ino.elf" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/G26_Mesh_Validation_Tool.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/I2CPositionEncoder.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/M100_Free_Mem_Chk.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/Marlin.ino.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/MarlinSerial.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/Marlin_main.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/Max7219_Debug_LEDs.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/Sd2Card.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/SdBaseFile.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/SdFatUtil.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/SdFile.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/SdVolume.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/blinkm.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/cardreader.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/configuration_store.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/dac_mcp4728.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/digipot_mcp4018.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/digipot_mcp4451.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/endstops.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/gcode.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/hex_print_routines.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/least_squares_fit.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/leds.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/mesh_bed_leveling.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/neopixel.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/nozzle.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/pca9632.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/planner.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/planner_bezier.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/printcounter.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/serial.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/servo.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/stepper.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/stepper_dac.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/stepper_indirection.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/stopwatch.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/temperature.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/twibus.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/ubl.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/ubl_G29.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/ubl_motion.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/ultralcd.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/utility.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/vector_3.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/sketch/watchdog.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/libraries/LiquidCrystal/LiquidCrystal.cpp.o" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/core/core.a" "-L/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068" -lm
"/Users/flo/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/Marlin.ino.elf" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/Marlin.ino.eep"
"/Users/flo/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -R .eeprom  "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/Marlin.ino.elf" "/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/Marlin.ino.hex"
Utilisation de la bibliothèque LiquidCrystal version 1.0.5 dans le dossier: /Applications/Arduino.app/Contents/Java/libraries/LiquidCrystal
Le croquis utilise 110508 octets (87%) de l'espace de stockage de programmes. Le maximum est de 126976 octets.
Les variables globales utilisent 4191 octets de mémoire dynamique.
/Users/flo/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/Users/flo/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf -v -patmega1284p -carduino -P/dev/cu.wchusbserial1410 -b57600 -D -Uflash:w:/var/folders/19/rnmwqj2j43xc40796k9xfvw80000gn/T/arduino_build_642068/Marlin.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/flo/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf"
         User configuration file is "/Users/flo/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.wchusbserial1410
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xbf
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xae
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd6
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x02
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xcc
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd6
avrdude done.  Thank you.
Une erreur est survenue lors du transfert du croquis
Pouvez vous me donner une piste pour solutionner ce problème ?
J'ai essayer sur un Windows mais j'ai la même erreur,.... : >:(
Merci d'avance pour votre aide.
Salut
Tu aurais pu au moins préciser le type de carte.
Commence par ICI.
