je les ai installées toutes
voici le messaged'erreur
Arduino : 1.8.13 (Windows 10), Carte : "Arduino Micro"
arduino_sigma_70-300mm:8:18: error: no matching function for call to 'TM1637::TM1637(int&, int&)'
TM1637 tm(CLK,DIO);
In file included from C:\Users\XXXXXXX\Documents\Arduino\arduino_sigma_70-300mm\arduino_sigma_70-300mm.ino:3:0:
C:\Users\XXXXXXX\Documents\Arduino\libraries\TM1637_RT/TM1637.h:22:5: note: candidate: TM1637::TM1637()
TM1637();
C:\Users\XXXXXXX\Documents\Arduino\libraries\TM1637_RT/TM1637.h:22:5: note: candidate expects 0 arguments, 2 provided
C:\Users\XXXXXXX\Documents\Arduino\libraries\TM1637_RT/TM1637.h:19:7: note: candidate: constexpr TM1637::TM1637(const TM1637&)
class TM1637
C:\Users\XXXXXX\Documents\Arduino\libraries\TM1637_RT/TM1637.h:19:7: note: candidate expects 1 argument, 2 provided
C:\Users\XXX\Documents\Arduino\libraries\TM1637_RT/TM1637.h:19:7: note: candidate: constexpr TM1637::TM1637(TM1637&&)
C:\Users\XXXXX\Documents\Arduino\libraries\TM1637_RT/TM1637.h:19:7: note: candidate expects 1 argument, 2 provided
C:\Users\XXXXX\Documents\Arduino\arduino_sigma_70-300mm\arduino_sigma_70-300mm.ino: In function 'void setup()':
arduino_sigma_70-300mm:24:11: error: no matching function for call to 'TM1637::init()'
tm.init();
In file included from C:\Users\XXX\Documents\Arduino\arduino_sigma_70-300mm\arduino_sigma_70-300mm.ino:3:0:
C:\Users\XXXXX\Documents\Arduino\libraries\TM1637_RT/TM1637.h:24:10: note: candidate: void TM1637::init(uint8_t, uint8_t, uint8_t)
void init(uint8_t clockPin, uint8_t dataPin, uint8_t digits = 6);
C:\Users\XXXX\Documents\Arduino\libraries\TM1637_RT/TM1637.h:24:10: note: candidate expects 3 arguments, 0 provided
arduino_sigma_70-300mm:25:6: error: 'class TM1637' has no member named 'set'
tm.set(1);
C:\Users\XXXXX\Documents\Arduino\arduino_sigma_70-300mm\arduino_sigma_70-300mm.ino: In function 'void loop()':
arduino_sigma_70-300mm:40:10: error: 'class TM1637' has no member named 'display'; did you mean 'displayRaw'?
tm.display(2,7);
displayRaw
arduino_sigma_70-300mm:41:10: error: 'class TM1637' has no member named 'display'; did you mean 'displayRaw'?
tm.display(3,0);
displayRaw
arduino_sigma_70-300mm:45:10: error: 'class TM1637' has no member named 'display'; did you mean 'displayRaw'?
tm.display(1,1);
displayRaw
arduino_sigma_70-300mm:46:10: error: 'class TM1637' has no member named 'display'; did you mean 'displayRaw'?
tm.display(2,3);
displayRaw
arduino_sigma_70-300mm:47:10: error: 'class TM1637' has no member named 'display'; did you mean 'displayRaw'?
tm.display(3,5);
displayRaw
arduino_sigma_70-300mm:51:10: error: 'class TM1637' has no member named 'display'; did you mean 'displayRaw'?
tm.display(1,2);
displayRaw
arduino_sigma_70-300mm:52:10: error: 'class TM1637' has no member named 'display'; did you mean 'displayRaw'?
tm.display(2,0);
displayRaw
arduino_sigma_70-300mm:53:10: error: 'class TM1637' has no member named 'display'; did you mean 'displayRaw'?
tm.display(3,0);
displayRaw
arduino_sigma_70-300mm:57:10: error: 'class TM1637' has no member named 'display'; did you mean 'displayRaw'?
tm.display(1,3);
displayRaw
arduino_sigma_70-300mm:58:10: error: 'class TM1637' has no member named 'display'; did you mean 'displayRaw'?
tm.display(2,0);
displayRaw
arduino_sigma_70-300mm:59:10: error: 'class TM1637' has no member named 'display'; did you mean 'displayRaw'?
tm.display(3,0);
displayRaw
Plusieurs bibliothèque trouvées pour "TM1637.h"
Utilisé : C:\Users\XXXXX\Documents\Arduino\libraries\TM1637_RT
Non utilisé : C:\Users\XXXX\Documents\Arduino\libraries\Grove_4-Digit_Display
Non utilisé : C:\Users\XXXX\Documents\Arduino\libraries\TM1637_Driver
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
aussi tant qu'on parle des ecrans oled
comment puis-je afficher quelque chose en permanence
je m'explique
quant je dis à l'arduino de déplacer la focale de l'objectif sur 135mm par exemple
comment laisser 135 affiché sur l'écran ???
merci
cdt
