Problème lecture image carte SD/ écran TFT
Bonjour,
Mon matériel:
  • ESP32
  • Adafruit TFT FeatherWing - 3.5" 480x320 Touchscreen for Feathers
  • Carte SD Sandisk 64 gb
Je souhaite tester l'importation d'image sur mon écran tft
j'utilise donc le fichier exemple comme indiquer ici : Drawing Bitmaps | Adafruit 3.5" 480x320 TFT FeatherWing | Adafruit Learning System
une fois que j'upload mon programme dans ma console j'ai ce message d'erreur
Initializing filesystem...SD begin() failed
Pourriez vous m'aider ?
Le programme exemple :
// Adafruit_ImageReader test for 3.5" TFT FeatherWing. Demonstrates loading
// images from SD card or flash memory to the screen, to RAM, and how to
// query image file dimensions. OPEN THE ARDUINO SERIAL MONITOR WINDOW TO
// START PROGRAM. Requires three BMP files in root directory of SD card or
// flash: adabot.bmp, parrot.bmp and wales.bmp.
#include <Adafruit_GFX.h>         // Core graphics library
#include <Adafruit_HX8357.h>      // Hardware-specific library
#include <SdFat.h>                // SD card & FAT filesystem library
#include <Adafruit_SPIFlash.h>    // SPI / QSPI flash library
#include <Adafruit_ImageReader.h> // Image-reading functions
// Comment out the next line to load from SPI/QSPI flash instead of SD card:
#define USE_SD_CARD
// Pin definitions for 2.4" TFT FeatherWing vary among boards...
#if defined(ESP8266)
  #define TFT_CS   0
  #define TFT_DC   15
  #define SD_CS    2
#elif defined(ESP32)
  #define TFT_CS   15
  #define TFT_DC   33
  #define SD_CS    14
#elif defined(TEENSYDUINO)
  #define TFT_DC   10
  #define TFT_CS   4
  #define SD_CS    8
#elif defined(ARDUINO_STM32_FEATHER)
  #define TFT_DC   PB4
  #define TFT_CS   PA15
  #define SD_CS    PC5
#elif defined(ARDUINO_NRF52832_FEATHER) // BSP 0.6.5 and higher!
  #define TFT_DC   11
  #define TFT_CS   31
  #define SD_CS    27
#elif defined(ARDUINO_MAX32620FTHR) || defined(ARDUINO_MAX32630FTHR)
  #define TFT_DC   P5_4
  #define TFT_CS   P5_3
  #define STMPE_CS P3_3
  #define SD_CS    P3_2
#else // Anything else!
  #define TFT_CS   9
  #define TFT_DC   10
  #define SD_CS    5
#endif
#if defined(USE_SD_CARD)
  SdFat                SD;         // SD card filesystem
  Adafruit_ImageReader reader(SD); // Image-reader object, pass in SD filesys
#else
  // SPI or QSPI flash filesystem (i.e. CIRCUITPY drive)
  #if defined(__SAMD51__) || defined(NRF52840_XXAA)
    Adafruit_FlashTransport_QSPI flashTransport(PIN_QSPI_SCK, PIN_QSPI_CS,
      PIN_QSPI_IO0, PIN_QSPI_IO1, PIN_QSPI_IO2, PIN_QSPI_IO3);
  #else
    #if (SPI_INTERFACES_COUNT == 1)
      Adafruit_FlashTransport_SPI flashTransport(SS, &SPI);
    #else
      Adafruit_FlashTransport_SPI flashTransport(SS1, &SPI1);
    #endif
  #endif
  Adafruit_SPIFlash    flash(&flashTransport);
  FatFileSystem        filesys;
  Adafruit_ImageReader reader(filesys); // Image-reader, pass in flash filesys
#endif
Adafruit_HX8357        tft    = Adafruit_HX8357(TFT_CS, TFT_DC);
Adafruit_Image         img;        // An image loaded into RAM
int32_t                width  = 0, // BMP image dimensions
                       height = 0;
void setup(void) {
  ImageReturnCode stat; // Status from image-reading functions
#if !defined(ESP32)
  while(!Serial);       // Wait for Serial Monitor before continuing
#endif
  tft.begin();          // Initialize screen
  // The Adafruit_ImageReader constructor call (above, before setup())
  // accepts an uninitialized SdFat or FatFileSystem object. This MUST
  // BE INITIALIZED before using any of the image reader functions!
  Serial.print(F("Initializing filesystem..."));
  // SD card is pretty straightforward, a single call...
  if(!SD.begin(SD_CS, SD_SCK_MHZ(25))) { // ESP32 requires 25 MHz limit
    Serial.println(F("SD begin() failed"));
    for(;;); // Fatal error, do not continue
#else
  // SPI or QSPI flash requires two steps, one to access the bare flash
  // memory itself, then the second to access the filesystem within...
  if(!flash.begin()) {
    Serial.println(F("flash begin() failed"));
    for(;;);
  if(!filesys.begin(&flash)) {
    Serial.println(F("filesys begin() failed"));
    for(;;);
#endif
  Serial.println(F("OK!"));
  // Fill screen blue. Not a required step, this just shows that we're
  // successfully communicating with the screen.
  tft.fillScreen(HX8357_BLUE);
  // Load full-screen BMP file 'adabot.bmp' at position (0,0) (top left).
  // Notice the 'reader' object performs this, with 'tft' as an argument.
  Serial.print(F("Loading adabot.bmp to screen..."));
  stat = reader.drawBMP("/adabot.bmp", tft, 0, 0);
  // (Absolute path isn't necessary on most devices, but something
  // with the ESP32 SD library seems to require it.)
  reader.printStatus(stat);   // How'd we do?
  // Query the dimensions of image 'parrot.bmp' WITHOUT loading to screen:
  Serial.print(F("Querying parrot.bmp image size..."));
  stat = reader.bmpDimensions("/parrot.bmp", &width, &height);
  if(stat == IMAGE_SUCCESS) { // If it worked, print image size...
    Serial.print(F("Image dimensions: "));
    Serial.print(width);
    Serial.write('x');
    Serial.println(height);
  // Load small BMP 'wales.bmp' into a GFX canvas in RAM. This should
  // fail gracefully on AVR and other small devices, meaning the image
  // will not load, but this won't make the program stop or crash, it
  // just continues on without it.
  Serial.print(F("Loading wales.bmp to canvas..."));
  stat = reader.loadBMP("/wales.bmp", img);
  delay(2000); // Pause 2 seconds before moving on to loop()
  for(int r=0; r<4; r++) { // For each of 4 rotations...
    tft.setRotation(r);    // Set rotation
    tft.fillScreen(0);     // and clear screen
    // Load 4 copies of the 'parrot.bmp' image to the screen, some
    // partially off screen edges to demonstrate clipping. Globals
    // 'width' and 'height' were set by bmpDimensions() call in setup().
    for(int i=0; i<4; i++) {
      reader.drawBMP("/parrot.bmp", tft,
        (tft.width()  * i / 3) - (width  / 2),
        (tft.height() * i / 3) - (height / 2));
    delay(1000); // Pause 1 sec.
    // Draw 50 Welsh dragon flags in random positions. This has no effect
    // on memory-constrained boards like the Arduino Uno, where the image
    // failed to load due to insufficient RAM, but it's NOT fatal.
    for(int i=0; i<50; i++) {
      // Rather than reader.drawBMP() (which works from SD card),
      // a different function is used for RAM-resident images:
      img.draw(tft,                                    // Pass in tft object
        (int16_t)random(-img.width() , tft.width()) ,  // Horiz pos.
        (int16_t)random(-img.height(), tft.height())); // Vert pos
      // Reiterating a prior point: img.draw() does nothing and returns
      // if the image failed to load. It's unfortunate but not disastrous.
    delay(1000); // Pause 2 sec.
J'ai regardé un peu plus, je me demande si ce n'est pas ça ma carte SD est 64 gb donc en format exfat
et sur adafruit il parle de fat16 ou fat32 vous pensez que ça peut être ça le prb ?, il faut que je prenne une 4 gb à la place ?
