Problème lors de l'assemblage de deux code (impossible :0)
En gros j'ai fais deux codes le premier :
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xA8, 0x61, 0x0A, 0xAE, 0x05, 0x2A };
EthernetClient client;
char* host = "archive.karibsen.fr";
  Serial.println("Starting Arduino");
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    while (true) {}
  delay(2000);
  Serial.println("Conecting...");
  client.stop();
  if (client.connect(host, 80)) {
    Serial.println("-> Connected");
    String url = "/assets/php/add.php?ID=AB2C6D8F";
    client.print(String("GET ") + url + " HTTP/1.0\r\n" + "Host: " + host + "\r\n" + "User-Agent: ArduinoEthernet\r\n" + "Connection: close\r\n\r\n");
    Serial.println("Stuff done");
    while (client.connected()) {
      String line = client.readStringUntil('\n');
      Serial.println(line); //parse HTTP header
      if (line == "\r") {
      if (client.available()) {
    char c = client.read();
    String ce = String(c);
    if (ce.startsWith("none")) {
      Serial.print("NN");
      Serial.print(c);
  else {
    Serial.println("--> connection failed/n");
      Serial.print("NN");
      Serial.print(c);
et le deuxieme
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 9
#define RST_PIN 8
#define AccesFlag_PIN 2
#define Gate_PIN 3
#define Max_Acces 3
byte Count_acces=0;
byte CodeVerif=0;
byte Code_Acces[4]={0x67, 0xF3, 0x50, 0x39};
MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
// Init array that will store new NUID
byte nuidPICC[4];
  // Init RS232
  // Init SPI bus
  SPI.begin();
  // Init MFRC522
  rfid.PCD_Init();
  // Init LEDs
  pinMode(AccesFlag_PIN, OUTPUT);
  pinMode(Gate_PIN, OUTPUT);
  digitalWrite(AccesFlag_PIN, LOW);
  digitalWrite(Gate_PIN, LOW);
  // Initialisé la boucle si aucun badge n'est présent
  if ( !rfid.PICC_IsNewCardPresent())
    return;
  // Vérifier la présence d'un nouveau badge
  if ( !rfid.PICC_ReadCardSerial())
    return;
  // Afffichage
  Serial.println(("Un badge est détecté"));
  // Enregistrer l’ID du badge (4 octets)
  for (byte i = 0; i < 4; i++) {
    nuidPICC[i] = rfid.uid.uidByte[i];
  // Vérification du code
  CodeVerif= GetAccesState(Code_Acces,nuidPICC);
  if (CodeVerif!=1)
    Count_acces+=1;
    if(Count_acces==Max_Acces)
     // Dépassement des tentatives (clignotement infinie)
     while(1)
      digitalWrite(AccesFlag_PIN, HIGH);
      // Affichage
      Serial.println("Alerte!");
      asm("jmp 0x00");
      // Affichage
      Serial.println("Accès refusé");
      // Un seul clignotement: Code erroné
    // Affichage
    Serial.println("Bonjour");
    // Ouverture de la porte & Initialisation
    digitalWrite(Gate_PIN, HIGH);
    Count_acces=0;
  // Affichage de l'identifiant
  Serial.println(" L'UID du tag est:");
    Serial.print(nuidPICC[i], HEX);
    Serial.print(" ");
  // Re-Init RFID
  rfid.PICC_HaltA(); // Halt PICC
  rfid.PCD_StopCrypto1(); // Stop encryption on PCD
byte GetAccesState(byte *CodeAcces,byte *NewCode)
  byte StateAcces=0;
  if ((CodeAcces[0]==NewCode[0])&&(CodeAcces[1]==NewCode[1])&&
  (CodeAcces[2]==NewCode[2])&& (CodeAcces[3]==NewCode[3]))
    return StateAcces=1;
    return StateAcces=0;
J'aimerai que lorsque je passe une carte rfid cela me mette l'id, dans le lien qui me permet de me connecter au serveur
:warning:
Post mis dans la mauvaise section, on parle anglais dans les forums généraux. ➜ déplacé vers le forum francophone.
Merci de prendre en compte les recommandations listées dans "Les bonnes pratiques du Forum Francophone”
pour votre question, postez ce que vous avez essayé de faire
Tu peux déjà commencer par assembler les deux codes en un seul et le faire fonctionner. C'est un problème récurrent déjà traité plusieurs fois sur le forum. Ici par exemple.
