boujour, mon code marche tres bien sur mac mais quand j’arrive sur pc j’ai c’est erreurs
C:\Users\franc\Downloads\sketch_may24b\sketch_may24b.ino: In function 'void reset()':
C:\Users\franc\Downloads\sketch_may24b\sketch_may24b.ino:28:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
if(esp.find("OK") ) Serial.println("Module Reset");
C:\Users\franc\Downloads\sketch_may24b\sketch_may24b.ino: In function 'void connectWifi()':
C:\Users\franc\Downloads\sketch_may24b\sketch_may24b.ino:37:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
if(esp.find("OK")) {
C:\Users\franc\Downloads\sketch_may24b\sketch_may24b.ino: In function 'void httppost()':
C:\Users\franc\Downloads\sketch_may24b\sketch_may24b.ino:109:18: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
if( esp.find("OK")) {
C:\Users\franc\Downloads\sketch_may24b\sketch_may24b.ino:140:16: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
if(esp.find(">")) { Serial.println("Sending.."); esp.print(postRequest);
C:\Users\franc\Downloads\sketch_may24b\sketch_may24b.ino:142:23: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
if( esp.find("SEND OK")) { Serial.println("Packet sent");
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino\main.cpp: In function 'main':
C:\Users\franc\Downloads\sketch_may24b\sketch_may24b.ino:97:6: warning: offset outside bounds of constant string
data = "data=" + 50;// data sent must be under this form //name1=value1&name2=value2.
voici le code
#include "SoftwareSerial.h"
String ssid ="Colonna";
String password="***";
SoftwareSerial esp(10, 11);// RX, TX
String data;
String server = "192.168.1.81"; // www.example.com
String uri = "/data/add_data/elec";// our example is /esppost.php
int DHpin = 13;//sensor pin
byte dat [5];
String temp ,hum;
pinMode (DHpin, OUTPUT);
esp.begin(115200);
Serial.println("check");
reset();
connectWifi();
//reset the esp8266 module
void reset() {
esp.println("AT+RST");
//connect to your wifi network
void connectWifi() {
String cmd = "AT+CWJAP=\"" +ssid+"\",\"" + password + "\"";
esp.println(cmd);
delay(4000);
Serial.println("Connected!");
else {
connectWifi();
Serial.println("Cannot connect to wifi"); }
byte read_data () {
byte data;
for (int i = 0; i < 8; i ++) {
if (digitalRead (DHpin) == LOW) {
while (digitalRead (DHpin) == LOW); // wait for 50us
delayMicroseconds (30); // determine the duration of the high level to determine the data is '0 'or '1'
if (digitalRead (DHpin) == HIGH)
data |= (1 << (7-i)); // high front and low in the post
while (digitalRead (DHpin) == HIGH);
return data;
void start_test () {
digitalWrite (DHpin, LOW); // bus down, send start signal
delay (30); // delay greater than 18ms, so DHT11 start signal can be detected
digitalWrite (DHpin, HIGH);
delayMicroseconds (40); // Wait for DHT11 response
pinMode (DHpin, INPUT);
delayMicroseconds (80);
// DHT11 response, pulled the bus 80us
if (digitalRead (DHpin) == LOW);
// DHT11 80us after the bus pulled to start sending data
for (int i = 0; i < 4; i ++)
// receive temperature and humidity data, the parity bit is not considered
dat[i] = read_data ();
// send data once after releasing the bus, wait for the host to open the next Start signal
void loop () {
Serial.println("avant start test");
//start_test ();
// convert the bit data to string form
Serial.println("apres start test");
hum = String(dat[0]);
temp= String(dat[2]);
httppost();
void httppost () {
esp.println("AT+CIPSTART=\"TCP\",\"" + server + "\",80");//start a TCP connection.
Serial.println("TCP connection ready");
}else{
Serial.println("error TCP");
String postRequest =
"POST " + uri + " HTTP/1.0\r\n" +
"Host: " + server + "\r\n" +
"Accept: *" + "/" + "*\r\n" +
"Content-Length: " + data.length() + "\r\n" +
"Content-Type: application/x-www-form-urlencoded\r\n" +
"\r\n" + data;
String sendCmd = "AT+CIPSEND=";//determine the number of caracters to be sent.
esp.print(sendCmd);
esp.println(postRequest.length() );
while (esp.available()) {
String tmpResp = esp.readString();
Serial.println(tmpResp);
// close the connection
esp.println("AT+CIPCLOSE");
merci
