[code]#include <Arduino.h>
#include <Adafruit_DotStar.h>
#include <avr/power.h>
#include <avr/sleep.h>
#include <IRremote.h>
#include <SPI.h>
typedef uint16_t line_t;
// CONFIGURABLE STUFF ------------------------------------------------------
#include "graphics.h"
// Ideally you use hardware SPI as it's much faster, though limited to
// specific pins. If you really need to bitbang DotStar data & clock on
// different pins, optionally define those here:
// #define LED_DATA_PIN 11
// #define LED_CLOCK_PIN 13
// Empty and full thresholds (millivolts) used for battery level display:
#define BATT_MIN_MV 2000 // Some headroom over battery cutoff near 2.9V
#define BATT_MAX_MV 4000 // And little below fresh-charged battery near 4.1V
boolean autoCycle = true; // Set to true to cycle images by default
uint32_t CYCLE_TIME = 12; // Time, in seconds, between auto-cycle images
int RECV_PIN = 5;
IRrecv irrecv(RECV_PIN);
decode_results results;
#define BTN_BRIGHT_UP 0xFF3AC5
#define BTN_BRIGHT_DOWN 0xFFBA45
#define BTN_RESTART 0xFF827D
#define BTN_BATTERY 0xFD20DF
#define BTN_FASTER 0xFFE817
#define BTN_SLOWER 0xFFC837
#define BTN_OFF 0xFF02FD
#define BTN_PATTERN_PREV 0xFD10EF
#define BTN_PATTERN_NEXT 0xFD50AF
#define BTN_AUTOPLAY 0xFD906F
#define BTN_NONE 0
#if defined(LED_DATA_PIN) && defined(LED_CLOCK_PIN)
// Older DotStar LEDs use GBR order. If colors are wrong, edit here.
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS,
LED_DATA_PIN, LED_CLOCK_PIN, DOTSTAR_BGR);
#else
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS, DOTSTAR_BGR);
#endif
void imageInit(void),
IRinterrupt(void);
uint16_t readVoltage(void);
strip.begin(); // Allocate DotStar buffer, init SPI
strip.clear(); // Make sure strip is clear
strip.show(); // before measuring battery
imageInit(); // Initialize pointers for default image
irrecv.enableIRIn(); // Start the receiver
uint32_t lastImageTime = 0L, // Time of last image change
lastLineTime = 0L;
uint8_t imageNumber = 0, // Current image being displayed
imageType, // Image type: PALETTE[1,4,8] or TRUECOLOR
*imagePalette, // -> palette data in PROGMEM
*imagePixels, // -> pixel data in PROGMEM
palette[16][3]; // RAM-based color table for 1- or 4-bit images
line_t imageLines, // Number of lines in active image
imageLine; // Current line number in image
volatile uint16_t irCode = BTN_NONE; // Last valid IR code received
const uint8_t PROGMEM brightness[] = { 15, 31, 63, 127, 255 };
uint8_t bLevel = sizeof(brightness) - 1;
// Microseconds per line for various speed settings
const uint16_t PROGMEM lineTable[] = { // 375 * 2^(n/3)
1000000L / 375, // 375 lines/sec = slowest
1000000L / 472,
1000000L / 595,
1000000L / 750, // 750 lines/sec = mid
1000000L / 945,
1000000L / 1191,
1000000L / 1500 // 1500 lines/sec = fastest
uint8_t lineIntervalIndex = 3;
uint16_t lineInterval = 1000000L / 750;
void imageInit() { // Initialize global image state for current imageNumber
imageType = images[imageNumber].type;
imageLines = images[imageNumber].lines;
imageLine = 0;
imagePalette = (uint8_t *)images[imageNumber].palette;
imagePixels = (uint8_t *)images[imageNumber].pixels;
if (imageType == PALETTE1) memcpy_P(palette, imagePalette, 2 * 3);
else if (imageType == PALETTE4) memcpy_P(palette, imagePalette, 16 * 3);
lastImageTime = millis(); // Save time of image init for next auto-cycle
void nextImage(void) {
if (++imageNumber >= NUM_IMAGES) imageNumber = 0;
imageInit();
void prevImage(void) {
imageNumber = imageNumber ? imageNumber - 1 : NUM_IMAGES - 1;
imageInit();
// MAIN LOOP ---------------------------------------------------------------
uint32_t t = millis(); // Current time, milliseconds
if (autoCycle) {
if ((t - lastImageTime) >= (CYCLE_TIME * 1000L)) nextImage();
// CPU clocks vary slightly; multiple poi won't stay in perfect sync.
// Keep this in mind when using auto-cycle mode, you may want to cull
// the image selection to avoid unintentional regrettable combinations.
// Transfer one scanline from pixel data to LED strip:
switch (imageType) {
case PALETTE1: { // 1-bit (2 color) palette-based image
uint8_t pixelNum = 0, byteNum, bitNum, pixels, idx,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS / 8];
for (byteNum = NUM_LEDS / 8; byteNum--; ) { // Always padded to next byte
pixels = *ptr++; // 8 pixels of data (pixel 0 = LSB)
for (bitNum = 8; bitNum--; pixels >>= 1) {
idx = pixels & 1; // Color table index for pixel (0 or 1)
strip.setPixelColor(pixelNum++,
palette[idx][0], palette[idx][1], palette[idx][2]);
case PALETTE4: { // 4-bit (16 color) palette-based image
uint8_t pixelNum, p1, p2,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS / 2];
for (pixelNum = 0; pixelNum < NUM_LEDS; ) {
p2 = *ptr++; // Data for two pixels...
p1 = p2 >> 4; // Shift down 4 bits for first pixel
p2 &= 0x0F; // Mask out low 4 bits for second pixel
palette[p1][0], palette[p1][1], palette[p1][2]);
palette[p2][0], palette[p2][1], palette[p2][2]);
case PALETTE8: { // 8-bit (256 color) PROGMEM-palette-based image
uint16_t o;
uint8_t pixelNum,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS];
for (pixelNum = 0; pixelNum < NUM_LEDS; pixelNum++) {
o = *ptr++ * 3; // Offset into imagePalette
strip.setPixelColor(pixelNum,
imagePalette[o],
imagePalette[o + 1],
imagePalette[o + 2]);
case TRUECOLOR: { // 24-bit ('truecolor') image (no palette)
uint8_t pixelNum, r, g, b,
*ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS * 3];
r = *ptr++;
g = *ptr++;
b = *ptr++;
strip.setPixelColor(pixelNum, r, g, b);
if (++imageLine >= imageLines) imageLine = 0; // Next scanline, wrap around
IRinterrupt();
while (((t = micros()) - lastLineTime) < lineInterval) {
if (results.value != BTN_NONE) {
if (!strip.getBrightness()) { // If strip is off...
// Set brightness to last level
strip.setBrightness(brightness[bLevel]);
// and ignore button press (don't fall through)
// effectively, first press is 'wake'
switch (results.value) {
case BTN_BRIGHT_UP:
if (bLevel < (sizeof(brightness) - 1))
strip.setBrightness(brightness[++bLevel]);
case BTN_BRIGHT_DOWN:
if (bLevel)
strip.setBrightness(brightness[--bLevel]);
case BTN_FASTER:
CYCLE_TIME++;
if (lineIntervalIndex < (sizeof(lineTable) / sizeof(lineTable[0]) - 1))
lineInterval = lineTable[++lineIntervalIndex];
case BTN_SLOWER:
if (CYCLE_TIME > 0) CYCLE_TIME--;
if (lineIntervalIndex)
lineInterval = lineTable[--lineIntervalIndex];
case BTN_RESTART:
imageNumber = 0;
imageInit();
case BTN_OFF:
strip.setBrightness(0);
case BTN_PATTERN_PREV:
prevImage();
case BTN_PATTERN_NEXT:
nextImage();
case BTN_AUTOPLAY:
autoCycle = !autoCycle;
results.value = BTN_NONE;
strip.show(); // Refresh LEDs
lastLineTime = t;
void IRinterrupt() {
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
[/code]
Habe ein Paar Auskommentierte Zeilen Weggelassen damit ich nicht an der 9000 Zeichen Marke kratze
