Hallöchen,
ich hab n Problem und komm nicht mehr weiter.
Ich habe ein ESP32Cam und den Beispielcode geladen.
#include "esp_camera.h"
#include <WiFi.h>
// WARNING!!! PSRAM IC required for UXGA resolution and high JPEG quality
// Ensure ESP32 Wrover Module or other board with PSRAM is selected
// Partial images will be transmitted if image exceeds buffer size
// You must select partition scheme from the board menu that has at least 3MB APP space.
// Face Recognition is DISABLED for ESP32 and ESP32-S2, because it takes up from 15
// seconds to process single frame. Face Detection is ENABLED if PSRAM is enabled as well
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_ESP32S3_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
//#define CAMERA_MODEL_M5STACK_UNITCAM // No PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
//#define CAMERA_MODEL_XIAO_ESP32S3 // Has PSRAM
// ** Espressif Internal Boards **
//#define CAMERA_MODEL_ESP32_CAM_BOARD
//#define CAMERA_MODEL_ESP32S2_CAM_BOARD
//#define CAMERA_MODEL_ESP32S3_CAM_LCD
//#define CAMERA_MODEL_DFRobot_FireBeetle2_ESP32S3 // Has PSRAM
//#define CAMERA_MODEL_DFRobot_Romeo_ESP32S3 // Has PSRAM
#include "camera_pins.h"
// Enter your WiFi credentials
const char* ssid = "MeinRouter";
const char* password = "MeinPw";
void startCameraServer();
void setupLedFlash(int pin);
Serial.setDebugOutput(true);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sccb_sda = SIOD_GPIO_NUM;
config.pin_sccb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.frame_size = FRAMESIZE_UXGA;
config.pixel_format = PIXFORMAT_JPEG; // for streaming
//config.pixel_format = PIXFORMAT_RGB565; // for face detection/recognition
config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
config.fb_location = CAMERA_FB_IN_PSRAM;
config.jpeg_quality = 12;
config.fb_count = 1;
// if PSRAM IC present, init with UXGA resolution and higher JPEG quality
// for larger pre-allocated frame buffer.
if (config.pixel_format == PIXFORMAT_JPEG) {
if (psramFound()) {
config.jpeg_quality = 10;
config.fb_count = 2;
config.grab_mode = CAMERA_GRAB_LATEST;
// Limit the frame size when PSRAM is not available
config.frame_size = FRAMESIZE_SVGA;
config.fb_location = CAMERA_FB_IN_DRAM;
// Best option for face detection/recognition
config.frame_size = FRAMESIZE_240X240;
#if CONFIG_IDF_TARGET_ESP32S3
#endif
#if defined(CAMERA_MODEL_ESP_EYE)
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t* s = esp_camera_sensor_get();
// initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1); // flip it back
s->set_brightness(s, 1); // up the brightness just a bit
s->set_saturation(s, -2); // lower the saturation
// drop down frame size for higher initial frame rate
s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#endif
#if defined(CAMERA_MODEL_ESP32S3_EYE)
s->set_vflip(s, 1);
#endif
// Setup LED FLash if LED pin is defined in camera_pins.h
#if defined(LED_GPIO_NUM)
setupLedFlash(LED_GPIO_NUM);
#endif
WiFi.begin(ssid, password);
WiFi.setSleep(false);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
// Do nothing. Everything is done in another task by the web server
delay(10000);
Beim hochladen kommt die Fehlermeldung
exit status 1
Compilation error: 'ledcAttach' was not declared in this scope
Im Internet steht das sich am dem Befehlt "ledcAttach" und "ledcAttachPin" was geändert hat.
Wie ist die Einstellung in der IDE, wurde die Cam ausgewählt?
Habe auch eine Cam und die Funktioniert 1A mit dem Beispiel, musst nur Deine WLAN angaben er grenzen
#include <WiFi.h>
const char* ssid = "**********";
const char* password = "**********";
if(config.pixel_format == PIXFORMAT_JPEG){
if(psramFound()){
#endif
#endif
// camera init
return;
sensor_t * s = esp_camera_sensor_get();
s->set_vflip(s, 1);
#endif
s->set_vflip(s, 1);
#endif
#endif
Serial.print(".");
Serial.println("");
delay(10000);
extra getestet
Der Sketch verwendet 1497921 Bytes (47%) des Programmspeicherplatzes. Das Maximum sind 3145728 Bytes.
Globale Variablen verwenden 70796 Bytes (21%) des dynamischen Speichers, 256884 Bytes für lokale Variablen verbleiben. Das Maximum sind 327680 Bytes.
Ich habe 4 ESPcams, - bei 2 davon lässt sich der dieser Sketch nicht hochladen, die Fehlermeldung war aber eine andere, - hab ich aber nicht mehr im Kopf und gerade keinen Zugriff auf die Boards.
Aber:
Wenn ich das Bild im ansehe: Im Hintergrund sieht man dass die zweite Camera von aktiv ist, das ist aber nicht die AI Thinker sondern die ESP_EYE.
Ach ja mein ESP32 Core ist 2.0.9.
Du kannst versuchen mit der Portable IDE . Wie es geht steht hier:
Gestern oder Vorgestern war hier ein Fall wo die 2.3.2 auf einem Windows Rechner spinte.
Die Portable beißt sich nicht mit Deiner kennen nebeneinander "Laufen"
nicht störende parallel-Installation der IDE 1.8.19 als PORTABLE Installation
Was soll ich jetzt noch schreiben?
Willste jetzt deinen System erst einmal kreuz und quer zerschießen in dem du
wild drauflos installierst und die Anleitung NICHT beachtest
oder
meinst du kannst gleich beim ersten Anlauf mal eine Anleitung Schritt für Schritt befolgen?
OK, bei mir steht dort schon ledcAttachPin ... also hast Du eine ältere Version der ESP32 Board Libs installiert als ich...
Mach mal in der 2er IDE auf dieses ledcAttach einen Rechtsclick, Du bekommst dann eine Datei mit einer entsprechenden Funktion schreibgeschützt geöffnet.
Diese Funtion muss auch so heißen wie der Befehl den Du gezeigt hast. Wenn ich das nur in einer Datei ändere, bekomme ich den gleichen Fehler wie Du angezeigt.
Ich hatte als erstes die aktuelleste IDE (Arduino IDE 2.3.2) mit der ich den Fehler "exit status 1
Compilation error: 'ledcAttach' was not declared in this scope" hatte.
Dann schrieb
In meiner unwissenheit dachte ich er meint die IDE version.
Mach dir mal keine sorgen um mein system ich habs auf einem anderen PC installiert.
Version 2.0.9 kann ich garnicht auswählen nur Version 2.0.10 (mit der der gleiche Fehler kommt)
