Hallo und guten Abend,
ich habe das (mitgelieferte Beispiel!!!) TFTDisplayText.ino ausprobiert
und erhalte diesen Fehler:
C:\Users\Thomas\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\Thomas\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32s3/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_HELTEC_WIFI_KIT_32_V3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="HELTEC_WIFI_KIT_32_V3" -DARDUINO_VARIANT="heltec_wifi_kit_32_V3" -DARDUINO_PARTITION_default_8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:heltec_wifi_kit_32_V3:UploadSpeed=921600,CPUFreq=240,DebugLevel=none,LoopCore=1,EventsCore=1,EraseFlash=none" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\Thomas\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32s3/flags/defines -IC:\Users\Thomas\AppData\Local\Temp\.arduinoIDE-unsaved2024106-1284-phlbng.fdho9\TFTDisplayText -iprefix C:\Users\Thomas\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32s3/include/ @C:\Users\Thomas\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32s3/flags/includes -IC:\Users\Thomas\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32s3/qio_qspi/include -IC:\Users\Thomas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Thomas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\heltec_wifi_kit_32_V3 -IC:\Users\Thomas\AppData\Local\Arduino15\libraries\TFT\src -IC:\Users\Thomas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\SPI\src @C:\Users\Thomas\AppData\Local\Temp\arduino\sketches\B1F4F45BE3F2C607B2D7F919B273E245/build_opt.h @C:\Users\Thomas\AppData\Local\Temp\arduino\sketches\B1F4F45BE3F2C607B2D7F919B273E245/file_opts C:\Users\Thomas\AppData\Local\Arduino15\libraries\TFT\src\utility\Adafruit_GFX.cpp -o nul
In file included from C:\Users\Thomas\AppData\Local\Arduino15\libraries\TFT\src\utility\Adafruit_GFX.cpp:35:
C:\Users\Thomas\AppData\Local\Arduino15\libraries\TFT\src\utility\glcdfont.c:7:14: fatal error: io.h: No such file or directory
7 | #include <io.h>
compilation terminated.
Alternativen für io.h: []
ResolveLibrary(io.h)
-> Kandidaten: []
exit status 1
Compilation error: exit status 1
Keines der Beispielprogramme, die TFT betreffen lässt sich Compilieren,
die Fehlermeldungen sind wie angegeben oder ähnlich.
(Datei nicht vorhanden)
Das Internet (auch dieses Forum) hat sich mit diesem Fehler in der Vergangenheit schon befasst, aber keine der dort gezeigten Lösungen löst mein Problem.
(Vergleiche Case vom 25.Juli 2018, 12:16).
Hat jemand eine Lösung, die auch funzt?
VG Thomas
