Hi, I git some trouble with installing of the Libary SSD1331.
I got folowing error message:
Arduino: 1.8.2 (Windows 10), Board: "Arduino Nano, ATmega328"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\nimic\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10802 -build-path C:\Users\nimic\AppData\Local\Temp\arduino_build_111439 -warnings=all -build-cache C:\Users\nimic\AppData\Local\Temp\arduino_cache_656367 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\nimic\Documents\Arduino\libraries\Adafruit-SSD1331-OLED-Driver-Library-for-Arduino-master\examples\test\test.pde
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\nimic\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10802 -build-path C:\Users\nimic\AppData\Local\Temp\arduino_build_111439 -warnings=all -build-cache C:\Users\nimic\AppData\Local\Temp\arduino_cache_656367 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\nimic\Documents\Arduino\libraries\Adafruit-SSD1331-OLED-Driver-Library-for-Arduino-master\examples\test\test.pde
Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\nimic\AppData\Local\Temp\arduino_build_111439\sketch\test.pde.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\nimic\AppData\Local\Temp\arduino_build_111439\sketch\test.pde.cpp" -o "C:\Users\nimic\AppData\Local\Temp\arduino_build_111439\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\nimic\Documents\Arduino\libraries\Adafruit-SSD1331-OLED-Driver-Library-for-Arduino-master\examples\test\test.pde:38:26: fatal error: Adafruit_GFX.h: No such file or directory
#include <Adafruit_GFX.h>
compilation terminated.
exit status 1
Fehler beim Kompilieren für das Board Arduino Nano.
But the file is in the right directory? (see att.)
Thanks for helping
Michael
