Problème programmation
Bonjour, récemment j'ai eu un petit problème concernant la programmation d'un code, je vais vous montrez un copier de l'erreur et du programme :
Erreur : Arduino : 1.6.12 (Windows 7), Carte : "Arduino/Genuino Uno"
Cligno._led_01:20: error: expected initializer before 'pinMode'
pinMode (led1 OUTPUT);
Cligno._led_01:21: error: expected constructor, destructor, or type conversion before '(' token
pinMode (led2 OUTPUT);
Cligno._led_01:22: error: expected constructor, destructor, or type conversion before '(' token
pinMode (led3 OUTPUT);
Cligno._led_01:27: error: expected initializer before 'digitalWrite'
digitalWrite (led1, HIGH); // allume led 1
Cligno._led_01:28: error: expected constructor, destructor, or type conversion before '(' token
delay (1000) ; // attend 1 sec.
Cligno._led_01:29: error: expected constructor, destructor, or type conversion before '(' token
digitalWrite (led1, LOW); // éteint led 1
Cligno._led_01:30: error: expected constructor, destructor, or type conversion before '(' token
delay (1000) ; // att. 1 sec.
Cligno._led_01:32: error: expected constructor, destructor, or type conversion before '(' token
digitalWrite (led2, HIGH) ; // all. led 2
Cligno._led_01:33: error: expected constructor, destructor, or type conversion before '(' token
Cligno._led_01:34: error: expected constructor, destructor, or type conversion before '(' token
digitalWrite (led2 , LOW) ; // éteint led 2
Cligno._led_01:35: error: expected constructor, destructor, or type conversion before '(' token
delay (1000) ; // att 1 sec.
Cligno._led_01:37: error: expected constructor, destructor, or type conversion before '(' token
digitalWrite (led3, HIGH) ; // all. led 3
Cligno._led_01:38: error: expected constructor, destructor, or type conversion before '(' token
Cligno._led_01:39: error: expected constructor, destructor, or type conversion before '(' token
digitalWrite ((led3, LOW) ; // etaint led 3
Cligno._led_01:41: error: expected declaration before '}' token
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
Le programme :
Comment gérer les sorties digitales
Cet exemple montre comment gérer les sorties d'Arduino pour allumer de manière séquentielle les 3 led
//def. broches
int led1 = 11;
int led2 = 12;
int led3 = 13;
void setup ()
//config. broches en sorties
void loop ()
Merci,
Cordialement.
  1. Code entre balise !
  2. les erreur sont claire :
  • tu as deux fois void setup et void loop
  • la configuration est mal réalisé, il manque des virgules
  • il manque plein de { et de }
