Problème requestFrom librairie wire.h
Bonjour à tous,
J'ai un problème dans un code que j'ai récupéré sur github. Il doit faire fonctionner une board avec un capteur de pression BMP390. Le problème c'est que j'ai deux erreurs dans mon code :
In function 'uint8_t readByte(uint8_t)':
 note: candidate 1: uint8_t TwoWire::requestFrom(int, int)
     uint8_t requestFrom(int, int);
note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t)
     uint8_t requestFrom(uint8_t, uint8_t);
In function 'void readBytes(uint8_t, uint8_t*, uint16_t)':
Le code pour la board est :
#include<Wire.h>
#define BMP390_I2C_ADDR       0x77        // The BMP390 I2C address
#define BMP390_I2C_ALT_ADDR   0x76        // The BMP390 I2C alternate address
#define BMP390_ID             0x50        // The BMP390 device ID
#define BMP390_ID             0x60        // The BMP390 device ID
#define RESET_CODE            0xB6        // The BMP390 reset code
#define FIFO_FLUSH            0xB0        // The BMP390 flush FIFO code
#define Address               0x77        // I2C so we used
#define BMPAdd                0x77
enum {
  BMP390_CHIP_ID         = 0x00,          // Chip ID register sub-address
  BMP390_ERR_REG         = 0x02,          // Error register sub-address
  BMP390_STATUS          = 0x03,          // Status register sub-address
  BMP390_DATA_0          = 0x04,          // Pressure eXtended Least Significant Byte (XLSB) register sub-address
  BMP390_DATA_1          = 0x05,          // Pressure Least Significant Byte (LSB) register sub-address
  BMP390_DATA_2          = 0x06,          // Pressure Most Significant Byte (MSB) register sub-address
  BMP390_DATA_3          = 0x07,          // Temperature eXtended Least Significant Byte (XLSB) register sub-address
  BMP390_DATA_4          = 0x08,          // Temperature Least Significant Byte (LSB) register sub-address
  BMP390_DATA_5          = 0x09,          // Temperature Most Significant Byte (MSB) register sub-address
  BMP390_SENSORTIME_0    = 0x0C,          // Sensor time register 0 sub-address
  BMP390_SENSORTIME_1    = 0x0D,          // Sensor time register 1 sub-address
  BMP390_SENSORTIME_2    = 0x0E,          // Sensor time register 2 sub-address
  BMP390_EVENT           = 0x10,          // Event register sub-address
  BMP390_INT_STATUS      = 0x11,          // Interrupt Status register sub-address
  BMP390_FIFO_LENGTH_0   = 0x12,          // FIFO Length Least Significant Byte (LSB) register sub-address
  BMP390_FIFO_LENGTH_1   = 0x13,          // FIFO Length Most Significant Byte (MSB) register sub-address
  BMP390_FIFO_DATA       = 0x14,          // FIFO Data register sub-address
  BMP390_FIFO_WTM_0      = 0x15,          // FIFO Water Mark Least Significant Byte (LSB) register sub-address
  BMP390_FIFO_WTM_1      = 0x16,          // FIFO Water Mark Most Significant Byte (MSB) register sub-address
  BMP390_FIFO_CONFIG_1   = 0x17,          // FIFO Configuration 1 register sub-address
  BMP390_FIFO_CONFIG_2   = 0x18,          // FIFO Configuration 2 register sub-address
  BMP390_INT_CTRL        = 0x19,          // Interrupt Control register sub-address
  BMP390_IF_CONFIG       = 0x1A,          // Interface Configuration register sub-address
  BMP390_PWR_CTRL        = 0x1B,          // Power Control register sub-address
  BMP390_OSR             = 0x1C,          // Oversampling register sub-address
  BMP390_ODR             = 0x1D,          // Output Data Rate register sub-address
  BMP390_CONFIG          = 0x1F,          // Configuration register sub-address
  BMP390_TRIM_PARAMS     = 0x31,          // Trim parameter registers' base sub-address
  BMP390_CMD             = 0x7E           // Command register sub-address
 struct {                                                    // The BMP390 compensation trim parameters (coefficients)
      uint16_t param_T1;
      uint16_t param_T2;
      int8_t   param_T3;
      int16_t  param_P1;
      int16_t  param_P2;
      int8_t   param_P3;
      int8_t   param_P4;
      uint16_t param_P5;
      uint16_t param_P6;
      int8_t   param_P7;
      int8_t   param_P8;
      int16_t  param_P9;
      int8_t   param_P10;
      int8_t   param_P11;
 }params;
    struct FloatParams {                                        // The BMP388 float point compensation trim parameters
      float param_T1;
      float param_T2;
      float param_T3;
      float param_P1;
      float param_P2;
      float param_P3;
      float param_P4;
      float param_P5;
      float param_P6;
      float param_P7;
      float param_P8;
      float param_P9;
      float param_P10;
      float param_P11;
    } floatParams;
  Wire.begin();
  Wire.begin();
//  //register 0x1F config
//  Wire.beginTransmission(BMPAdd);
//  Wire.write(0x1F);
//  Wire.write();
//  Wire.endTransmission(true);
  //Register 0x1C OSR
  Wire.write(0x1C);
  Wire.write(0b00000000);
  //Register 0x1D ODR
  Wire.write(0x1D);
  //register pwr_ctrl 0x1B
  Wire.write(0x1B);
  Wire.write(0b00110011);
  //register FIFO_CONFIG2 0x18
  Wire.write(0x18);
  Wire.write(0b00001000);
  //register FIFO_CONFIG1 0x17
  Wire.write(0x17);
  Wire.write(0b00011001);
  //register INT_STATUS 0x11
  Wire.write(0x11);
  Wire.write(0b00000011);
  Wire.endTransmission();
  //register EVENT 0x10
  Wire.write(0x10);
 //register CHIP_ID
 Wire.write(0x00);
 Wire.write(0x60);
  long address=BMP390_I2C_ADDR;
   readBytes(BMP390_TRIM_PARAMS, (uint8_t*)&params, sizeof(params)); // Read the trim parameters into the params structure
  floatParams.param_T1 = (float)params.param_T1 / powf(2.0f, -8.0f); // Calculate the floating point trim parameters
  floatParams.param_T2 = (float)params.param_T2 / powf(2.0f, 30.0f);
  floatParams.param_T3 = (float)params.param_T3 / powf(2.0f, 48.0f);
  floatParams.param_P1 = ((float)params.param_P1 - powf(2.0f, 14.0f)) / powf(2.0f, 20.0f);
  floatParams.param_P2 = ((float)params.param_P2 - powf(2.0f, 14.0f)) / powf(2.0f, 29.0f);
  floatParams.param_P3 = (float)params.param_P3 / powf(2.0f, 32.0f);
  floatParams.param_P4 = (float)params.param_P4 / powf(2.0f, 37.0f);
  floatParams.param_P5 = (float)params.param_P5 / powf(2.0f, -3.0f);
  floatParams.param_P6 = (float)params.param_P6 / powf(2.0f, 6.0f);
  floatParams.param_P7 = (float)params.param_P7 / powf(2.0f, 8.0f);
  floatParams.param_P8 = (float)params.param_P8 / powf(2.0f, 15.0f);
  floatParams.param_P9 = (float)params.param_P9 / powf(2.0f, 48.0f);
  floatParams.param_P10 = (float)params.param_P10 / powf(2.0f, 48.0f);
  floatParams.param_P11 = (float)params.param_P11 / powf(2.0f, 65.0f);
getTempPres();
// read single byte........................................................................................................................................................................
uint8_t readByte(uint8_t subAddress)                        // Read a byte from the sub-address using I2C
    uint8_t data = 0x00;
    Wire.beginTransmission(Address);
    Wire.write(subAddress);
    Wire.endTransmission(false);
    Wire.requestFrom(Address, (uint8_t)1);
    data = Wire.read();
  return data;                                                      // Return data read from sub-address register
// read multiple bytes from I2C...........................................................................................................................................................
void readBytes(uint8_t subAddress, uint8_t* data, uint16_t count)
    // Read "count" bytes into the "data" buffer using I2C
    uint8_t i = 0;
    Wire.requestFrom(Address, (uint8_t)count);
    while (Wire.available())
      data[i++] = Wire.read();
      delay(4.5);
//      Serial.println(data[i]);
//...........................................................Read temperature and pressure.............................................................................................
  uint8_t getTempPres(){
  float temperature;
  float pressure;
  uint8_t data[6];
  // Create a data buffer
  readBytes(BMP390_DATA_0, &data[0], 6);                            // Read the temperature and pressure data
  int32_t adcTemp = (int32_t)data[5] << 16 | (int32_t)data[4] << 8 | (int32_t)data[3];  // Copy the temperature and pressure data into the adc variables
  int32_t adcPres = (int32_t)data[2] << 16 | (int32_t)data[1] << 8 | (int32_t)data[0];
  temperature = bmp390_compensate_temp((float)adcTemp);             // Temperature compensation (function from BMP388 datasheet)
  pressure = bmp390_compensate_press((float)adcPres, temperature);  // Pressure compensation (function from BMP388 datasheet)
  pressure /= 100.0f;                                               // Calculate the pressure in millibar/hPa
  Serial.print("temperature : ");
  Serial.println(temperature);
  Serial.print("pressure : ");
  Serial.println(pressure);
//.................................................................compensate raw temperature algorithm from datasheet...................................................................
float bmp390_compensate_temp(float uncomp_temp)
  float partial_data1 = uncomp_temp - floatParams.param_T1;
  float partial_data2 = partial_data1 * floatParams.param_T2;
  return partial_data2 + partial_data1 * partial_data1 * floatParams.param_T3;
float bmp390_compensate_press(float uncomp_press, float t_lin)
  float partial_data1 = floatParams.param_P6 * t_lin;
  float partial_data2 = floatParams.param_P7 * t_lin * t_lin;
  float partial_data3 = floatParams.param_P8 * t_lin * t_lin * t_lin;
  float partial_out1 = floatParams.param_P5 + partial_data1 + partial_data2 + partial_data3;
  partial_data1 = floatParams.param_P2 * t_lin;
  partial_data2 = floatParams.param_P3 * t_lin * t_lin;
  partial_data3 = floatParams.param_P4 * t_lin * t_lin * t_lin;
  float partial_out2 = uncomp_press * (floatParams.param_P1 +
  partial_data1 + partial_data2 + partial_data3);
  partial_data1 = uncomp_press * uncomp_press;
  partial_data2 = floatParams.param_P9 + floatParams.param_P10 * t_lin;
  partial_data3 = partial_data1 * partial_data2;
  float partial_data4 = partial_data3 + uncomp_press * uncomp_press * uncomp_press * floatParams.param_P11;
  return partial_out1 + partial_out2 + partial_data4;
Si vous avez une idée d'ou cela peut provenir , merci à vous ! :slightly_smiling_face:
Bonjour et bienvenue,
Merci de prendre quelques minutes pour lire les bonnes pratiques du forum francophone et les appliquer.
Ce serait bien d'avoir le code qui a généré l'erreur.
Désolé j'ai oublié de mettre le code , je viens d'actualiser
hello
tu avais vu ce lien?ICI
il faut descendre dans la page pour trouver librairie et exemples.
Il faut remplacer ça:
par ça:
const uint8_t Address = 0x77;
Les define sont interprétés par défaut comme des int d'où l'erreur
Il reste encore ces warning à corriger si tu veux que ton code fonctionne correctement
BMP390_ID défini 2 fois
Et la fonction getTempPres()' censée retourner une valeur et qui ne retourne rien
tmp/.arduinoIDE-unsaved2023528-12124-1b6efp2.9c42/sketch_jun28a/sketch_jun28a.ino:5:0: warning: "BMP390_ID" redefined
/tmp/.arduinoIDE-unsaved2023528-12124-1b6efp2.9c42/sketch_jun28a/sketch_jun28a.ino:4:0: note: this is the location of the previous definition
/tmp/.arduinoIDE-unsaved2023528-12124-1b6efp2.9c42/sketch_jun28a/sketch_jun28a.ino: In function 'void setup()':
/tmp/.arduinoIDE-unsaved2023528-12124-1b6efp2.9c42/sketch_jun28a/sketch_jun28a.ino:140:8: warning: unused variable 'address' [-Wunused-variable]
/tmp/.arduinoIDE-unsaved2023528-12124-1b6efp2.9c42/sketch_jun28a/sketch_jun28a.ino: In function 'uint8_t getTempPres()':
/tmp/.arduinoIDE-unsaved2023528-12124-1b6efp2.9c42/sketch_jun28a/sketch_jun28a.ino:225:1: warning: no return statement in function returning non-void [-Wreturn-type]
salut merci pour ton retour , j'avais vu ceci cependant cette page est pour la board adafruit et j'ai une board différente ! merci à toi
En remplaçant la ligne define par const je n'ai plus aucune erreur , je te remercie pour l'aide ! Bonne après midi !
