Problème Robot 4wd avec moteur 12v
Bonjour à tous,
j'ai fabriqué un robot 4x4 avec 4 moteur 37GB-550 12V-480TR/MIN,
monter sur un BOUCLIER L293D,
télécommander par MOUDULE BLUETOOTH HC05,
les 4 moteurs sont alimentés par 3 piles 18650 4800mah 3.7A
la carte Arduino Uno R3, le bouclier L293D et le module Bluetooth HC05 sont alimentés par 2 piles 18650 4800mah 3.7A
voici le code que j'ai televersé :slight_smile:
#include <AFMotor.h>
//initial motors pin
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
char command;
  Serial.begin(9600);  //Set the baud rate to your Bluetooth module.
void loop(){
  if(Serial.available() > 0){
    command = Serial.read();
    Stop(); //initialize with motors stoped
    //Change pin mode only if new command is different from previous.
    //Serial.println(command);
    switch(command){
    case 'F':
      forward();
    case 'B':
       back();
    case 'L':
      left();
    case 'R':
      right();
void forward()
  motor1.setSpeed(255); //Define maximum velocity
  motor1.run(FORWARD); //rotate the motor clockwise
  motor2.setSpeed(255); //Define maximum velocity
  motor2.run(FORWARD); //rotate the motor clockwise
  motor3.setSpeed(255);//Define maximum velocity
  motor3.run(FORWARD); //rotate the motor clockwise
  motor4.setSpeed(255);//Define maximum velocity
  motor4.run(FORWARD); //rotate the motor clockwise
void back()
  motor1.run(BACKWARD); //rotate the motor anti-clockwise
  motor2.run(BACKWARD); //rotate the motor anti-clockwise
  motor3.setSpeed(255); //Define maximum velocity
  motor3.run(BACKWARD); //rotate the motor anti-clockwise
  motor4.setSpeed(255); //Define maximum velocity
  motor4.run(BACKWARD); //rotate the motor anti-clockwise
void left()
void right()
void Stop()
  motor1.setSpeed(0); //Define minimum velocity
  motor1.run(RELEASE); //stop the motor when release the button
  motor2.setSpeed(0); //Define minimum velocity
  motor2.run(RELEASE); //rotate the motor clockwise
  motor3.setSpeed(0); //Define minimum velocity
  motor3.run(RELEASE); //stop the motor when release the button
  motor4.setSpeed(0); //Define minimum velocity
  motor4.run(RELEASE); //stop the motor when release the button
mon problème c'est que le robot n'arrive pas à avancer, démarrer il reste immobile, comme ci les roues n'ont pas assez de puissance pour démarrer, sachant que j'ai réalisé un autre rebot en parallèle avec 4 moteurs 25GA370 MOTEUR CC 6V 230TR/MIN et il marche impeccable.
est ce que c'est un problème de code ?
aider moi svp
:warning: La rédaction de votre message ne répond pas aux critères attendus. Il n'aura sans doute pas de réponse tant que vous n'aurez pas pris en compte et mis en application les recommandations listées dans "Les bonnes pratiques du Forum Francophone” - en particulier les balises de code et un schéma de câblage
