Environment
- Development Kit: Arduino Nano ESP32
- Kit version (for WiKi): Not applicable
- Module or chip used: ESP32-S3-MINI-1-N8
- IDF version (run
git describe --tagsto find it):- Arduino-ESP32 Core: v2.0.18-arduino.5
- ESP-IDF: v4.4.7-dirty
- Build System: Arduino IDE 2.x
- Compiler version (run
xtensa-esp32-elf-gcc --versionto find it): xtensa-esp32s3-elf-gcc 2021r2-p5 - Operating System: Windows
- Using an IDE: Arduino IDE / PlatformIO
- Power Supply: USB
Problem Description
The TWAI (CAN) driver on ESP32-S3 reports successful message transmission (ESP_OK) but messages are not physically transmitted on the CAN bus. The twai_transmit() function completes in 0 milliseconds, which is physically impossible for actual CAN transmission at 500 kbit/s (should take 5-50ms).
This issue has been tested extensively with:
- Two different Arduino Nano ESP32 boards (both ESP32-S3)
- Multiple SN65HVD230D CAN transceivers
- Different GPIO pin combinations
- Various baudrates (500k, 125k, 25k)
- Both NORMAL and NO_ACK modes
- Multiple TWAI libraries (native API, ESP32-TWAI-CAN, arduino-CAN)
The result is always the same: 0ms transmission time = no physical output.
Expected Behavior
When calling twai_transmit() with a valid CAN message:
- Function should take 5-50ms to complete (depending on baudrate and bus arbitration)
- CAN message should be physically transmitted on CAN_H/CAN_L differential lines
- A second ESP32 board (receiver) should receive the message
- Multiple consecutive transmissions should work reliably
Actual Behavior
Observed with NORMAL Mode (2 boards connected):
[0] TX... OK (1ms) ← First message appears to work
[1] TX... OK (0ms) ← 0ms = NOT physically sent!
[2] TX... OK (0ms)
[3] TX... OK (0ms)
[4] TX... OK (0ms)
[5] TX... OK (0ms)
[6] TX... ERROR 263 (2000ms) ← ESP_ERR_TIMEOUT
[7] TX... ERROR 263 (2000ms)
Receiver board: No messages received (0 messages)
Observed with NO_ACK Mode (single board loopback):
[0] OK (32 µs)
[1] OK (7 µs)
[2-15] OK (7-11 µs) ← Works for ~15 messages
[16] ERROR 259 (3 µs) ← ESP_ERR_INVALID_STATE
[17+] ERROR 259 ← Continues failing
After error 259:
twai_status_info_t status:
state = TWAI_STATE_RECOVERING (2)
tx_error_counter = 128+
bus_error_count = increasing
Steps to Reproduce
Hardware Setup:
Board 1 (Sender):
Arduino Nano ESP32
├── GPIO 3 → SN65HVD230 TX (Pin 1)
├── GPIO 2 → SN65HVD230 RX (Pin 4)
├── GPIO 13 → SN65HVD230 Rs (Pin 8) [set to LOW for high-speed]
├── 3.3V → SN65HVD230 VCC
└── GND → SN65HVD230 GND
Board 2 (Receiver):
Same configuration as Board 1
CAN Bus Connection:
Board 1 CAN_H (Pin 7) ──┬── 120Ω ──┬── Board 2 CAN_H
Board 1 CAN_L (Pin 6) ──┤ ├── Board 2 CAN_L
Board 1 GND ────────────┴──────────┴── Board 2 GND
Cable: 30cm twisted-pair, 4-wire
Termination: 120Ω on both ends (measured ~60Ω total)
Software - Sender Code:
#include "driver/twai.h"
#define CAN_TX 3
#define CAN_RX 2
delay(2000);
Serial.println("TWAI Sender Test");
// Configure TWAI
twai_general_config_t g_config = TWAI_GENERAL_CONFIG_DEFAULT(
(gpio_num_t)CAN_TX,
(gpio_num_t)CAN_RX,
TWAI_MODE_NORMAL
twai_timing_config_t t_config = TWAI_TIMING_CONFIG_500KBITS();
twai_filter_config_t f_config = TWAI_FILTER_CONFIG_ACCEPT_ALL();
// Install and start
if (twai_driver_install(&g_config, &t_config, &f_config) == ESP_OK) {
Serial.println("Driver installed");
Serial.println("Driver install FAILED");
while(1);
if (twai_start() == ESP_OK) {
Serial.println("Driver started\n");
Serial.println("Driver start FAILED");
while(1);
static uint32_t counter = 0;
// Prepare message
twai_message_t msg;
msg.identifier = 0x101;
msg.data_length_code = 5;
msg.data[0] = 'H';
msg.data[1] = 'E';
msg.data[2] = 'L';
msg.data[3] = 'L';
msg.data[4] = 'O';
msg.extd = 0;
msg.rtr = 0;
// Measure transmission time
unsigned long start = millis();
esp_err_t err = twai_transmit(&msg, pdMS_TO_TICKS(2000));
unsigned long duration = millis() - start;
// Report
Serial.printf("[%lu] TX... ", counter);
if (err == ESP_OK) {
Serial.printf("OK (%lums)\n", duration); // Shows 0ms after first message!
Serial.printf("ERROR %d (%lums)\n", err, duration);
counter++;
delay(2000);
Software - Receiver Code:
#define CAN_TX 3
#define CAN_RX 2
delay(2000);
Serial.println("TWAI Receiver Test");
(gpio_num_t)CAN_TX,
(gpio_num_t)CAN_RX,
TWAI_MODE_NORMAL
twai_driver_install(&g_config, &t_config, &f_config);
twai_start();
Serial.println("Waiting for messages...\n");
twai_message_t msg;
if (twai_receive(&msg, pdMS_TO_TICKS(100)) == ESP_OK) {
Serial.println("=== MESSAGE RECEIVED ===");
Serial.printf("ID: 0x%03X\n", msg.identifier);
Serial.printf("DLC: %d\n", msg.data_length_code);
Serial.print("Data: ");
for (int i = 0; i < msg.data_length_code; i++) {
Serial.printf("%02X ", msg.data[i]);
Serial.println("\n========================\n");
Debug Information
Test 1: Different GPIO Pins Tested
| TX Pin | RX Pin | Result |
| GPIO 3 | GPIO 2 | 0ms (no transmission) |
| GPIO 0 | GPIO 1 | 0ms (no transmission) |
| GPIO 5 | GPIO 6 | 0ms (no transmission) |
All combinations show the same behavior.
Test 2: Different Baudrates Tested
| Baudrate | Result |
| 500 kbit/s | 0ms transmission |
| 125 kbit/s | 0ms transmission |
Baudrate makes no difference.
Test 3: Board Swap Test
Swapped sender and receiver code between boards → Same issue on both boards.
Conclusion: Not a hardware defect of individual board.
Test 4: SN65HVD230 Rs-Pin Configuration
Rs-Pin explicitly set to LOW (high-speed mode):
pinMode(13, OUTPUT);
digitalWrite(13, LOW); // Rs = LOW = High-Speed
Result: No change, still 0ms transmission.
Test 5: Different Libraries Tested
- Native TWAI API (
driver/twai.h):
0ms issue - ESP32-TWAI-CAN library (handmade0octopus):
Same 0ms issue - arduino-CAN library (sandeepmistry):
Doesn't compile for ESP32-S3
All libraries use the same underlying TWAI driver → same bug.
Additional Context
Community Reports
Multiple forum posts confirm TWAI issues on ESP32-S3:
- Created library for TWAI-CAN controller that is simple to use · espressif/arduino-esp32 · Discussion #9105 · GitHub
- Stack Overflow reports of S3 TWAI instability
- Community workaround: Use Modbus TCP over WiFi instead of CAN
Comparison with ESP32 Classic
The same code and hardware setup works reliably on ESP32 Classic (non-S3) boards.
This appears to be specific to ESP32-S3 TWAI implementation.
Suspected Root Cause
Based on behavior analysis:
twai_transmit()returns immediately (0ms) without waiting for physical transmission- TX error counter increases after ~15 messages in NO_ACK mode
- Bus enters RECOVERING state prematurely
Hypothesis: The ESP32-S3 TWAI peripheral may have:
- A bug in the transmission state machine
- Incorrect error handling causing premature bus-off
- GPIO matrix routing issues specific to S3
Workaround
Currently using Modbus TCP over WiFi as alternative communication method between devices.
Request
- Can you confirm this is a known issue with ESP32-S3 TWAI?
- Is there a planned fix in upcoming ESP-IDF or Arduino-ESP32 releases?
- Are there specific ESP32-S3 hardware revisions where TWAI works correctly?
- Should users avoid TWAI on ESP32-S3 and use alternatives (SPI CAN controllers, WiFi)?
System Logs
Full Serial Output (Sender)
``` TWAI Sender Test Driver installed Driver started[0] TX... OK (1ms)
[1] TX... OK (0ms)
[2] TX... OK (0ms)
[3] TX... OK (0ms)
[4] TX... OK (0ms)
[5] TX... OK (0ms)
[8] TX... ERROR 263 (2000ms)
</details>
<details>
<summary>Full Serial Output (Receiver)</summary>
TWAI Receiver Test
(no output - no messages received)
</details>
## Thank You
Thank you for maintaining this excellent framework. We appreciate any guidance or fixes you can provide for this issue.
