Problemi con librerie o settaggio RTC3231
Ciao a tutti,
Ho applicato ad un mio dispositivo un modulo RTC3231 a cui non riesco a regolare l'orario.
Ho applicato un comando di auto regolazione ma non ne vuole sapere.
#include <Wire.h>
#include <Wire.h>
#include "RTClib.h"
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define PIN_LAMP 3
#define PIN_BED 4
#define PIN_POMPA 5
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(128, 64, &Wire, OLED_RESET);
// real time clock
RTC_DS3231 rtc;
unsigned long t1, dt1, t2, dt2;
unsigned long t4, dt4;
int terra;
int th_terra = 30;
bool POMPA;
int t_on_pompa = 1000;
int statopompa = LOW;
unsigned long t3, dt3;
int tbed;
int th1_bed = 50;
int th2_bed = 69;
bool BED = LOW;
int t_on_bed = 1000;
int statobed = LOW;
int th1_luce = 80;
int th2_luce = 60;
int mm, hh;
bool GIORNO;
bool LAMP;
int luce = 0;
//icona sole
static const unsigned char PROGMEM logo8_sun_bmp[] =
{ B00010000,
  B01000010,
  B00011000,
  B00111101,
  B10111100,
  B00011000,
  B01000010,
  B00001000 };
static const unsigned char PROGMEM logo8_moon_bmp[] =
{ B00011100,
  B00110010,
  B01100000,
  B11100000,
  B11100000,
  B01100000,
  B00110010,
  B00011100 };
 static const unsigned char PROGMEM logo8_light_bmp[] =
{ B00011000,
  B01100110,
  B10000001,
  B10011001,
  B01000010,
  B00111100,
  B00100100,
  B00011000 };
static const unsigned char PROGMEM logo8_bed_bmp[] =
{ B01010100,
  B01010100,
  B00101010,
  B01010100,
  B01010100,
  B00000000,
  B11111111,
  B00000000 };
static const unsigned char PROGMEM logo8_water_bmp[] =
{ B00010000,
  B00010000,
  B00111000,
  B00111000,
  B01111100,
  B11111110,
  B01111100,
  B00111000 };
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x32
    Serial.println(F("SSD1306 allocation failed"));
    for(;;);
  if (!rtc.begin()) {
    Serial.println("Errore! Verifica le connesioni dell'RTC!");
    return;
  if (!rtc.begin()) {
    Serial.println("Configuro l'ora");
    //Uso l'ora di compilazione dello sketch
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // per farlo a mano...
    // January 21, 2014 at 3am you would call
    // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.cp437(true);
  display.clearDisplay();
  pinMode(PIN_LAMP, OUTPUT);  //luce
  pinMode(PIN_BED, OUTPUT);
  pinMode(PIN_POMPA, OUTPUT);
  digitalWrite(PIN_LAMP, LOW);
  digitalWrite(PIN_BED, LOW);
  digitalWrite(PIN_POMPA, LOW);
  leggiOra();
  leggiLuce();
  leggiTemperaturaBed();
  leggiTerra();
   * TIMER
  dt1 = millis() - t1;
  if (dt1 >= 2000) {
    t1 = millis();
    leggiLuce();
    leggiOra();
    leggiTerra();
  dt2 = millis() - t2;
  if (dt2 >= 200) {
    t2 = millis();
    aggiornaDisplay(luce);
  if (BED) {
    dt3 = millis() - t3;
    if (dt3 >= t_on_bed) {
      t3 = millis();
      statobed = !statobed;
      if (statobed) {
        digitalWrite(PIN_BED, HIGH);
        t_on_bed = 30000;
        t_on_bed = 5000;
  if (POMPA) {
    dt4 = millis() - t4;
    if (dt4 > t_on_pompa) {
      t4 = millis();
      statopompa = !statopompa;
      if (statopompa) {
        digitalWrite(PIN_POMPA, HIGH);
        t_on_pompa = 1000;
        t_on_pompa = 10000;
  //applico le azioni
  digitalWrite(PIN_LAMP, LAMP);
void leggiTerra(){
  terra = 0;
  for (int i = 0; i < 10; i++) {
    terra += analogRead(A1);
  terra = terra / 10;
  terra = map(terra, 0, 1024, 100, 0);
  Serial.println(terra);
  if (GIORNO) {
    if (terra < th_terra) {
      POMPA = HIGH;
      POMPA = LOW;
    POMPA = LOW;
    digitalWrite(PIN_POMPA,LOW);
void leggiTemperaturaBed() {
  tbed = 0;
    tbed += analogRead(A2);
  tbed = tbed / 10;
  tbed = map(tbed, 0, 1024, 0, 100);
  if (tbed < th1_bed) {
    BED = HIGH;
  } else if (tbed > th2_bed) {
    BED = LOW;
void leggiLuce() {
    luce += analogRead(A0);
  luce = luce / 10;
  luce = map (luce, 0, 1024, 0, 100);
  if (GIORNO) {
    if (luce > th1_luce) {
      LAMP = LOW;
    } else if (luce < th2_luce) {
      LAMP = HIGH;
    LAMP = LOW;
void leggiOra(){
  DateTime now = rtc.now();
  hh = now.hour();
  mm = now.minute();
  if ((hh >= 6) && (hh < 20)) {
    GIORNO = true;
    GIORNO = false;
void aggiornaDisplay(int luce) {
  //ore e minuti
  char timeBuff[6];     // 99:99+fine stringa
  sprintf(timeBuff, "%02u:%02u", hh,mm);
  display.setTextSize(2);
  display.setCursor(0, 20);
  display.print(timeBuff);
  display.setCursor(40, 50);
  display.print("T:");
  display.print(tbed);
  display.print("%");
  display.setCursor(0, 50);
  display.print("L:");
  display.print(luce);
  display.print("%");
  display.setCursor(80, 50);
  display.print("U:");
  display.print(terra);
  display.print("%");
  if (GIORNO) {
    display.drawBitmap(40, 0,  logo8_sun_bmp, 8, 8, 1);
    display.drawBitmap(40, 0,  logo8_moon_bmp, 8, 8, 1);
  if (LAMP) {
    display.drawBitmap(0, 0,  logo8_light_bmp, 8, 8, 1);
  if (BED) {
    display.drawBitmap(60, 0,  logo8_bed_bmp, 8, 8, 1);
  if (POMPA) {
    display.drawBitmap(80, 0,  logo8_water_bmp, 8, 8, 1);
  display.display();
Forse ho sbagliato quando ho deciso di scaricare tutte le librerie riguardanti RTC Lib?
Grazie
Che significa? Quale comando? Il DS3231, una volta rimesso, è più che preciso quindi ... quale autoregolazione?
Guglielmo
Rimuovi il punto esclamativo. begin() restituisce true se tutto e andato a buon fine, diversamente restituisce false.
Ora la negazione di true non può che essere false, cioè se il modulo rtc e collegato e funziona in quella if non ci entrerà mai. L'importante che comprendi questo punto. Ok, meglio il codice seguente:
  if (!rtc.begin()) {
    return;
  } else  {
Ma neanche questo va bene poiché ad ogni reset riparte da DATE e TIME. Ma dipende se è questo che vuoi.
Ciao.
Ah ... naturalmente tu sai che questa riga imposta il RTC alla data/ora in cui hai "compilato" il programma?
Guglielmo
Edit: mi sono sovrapposto con Maurotec :grin:
Quel comando prende ora e data di compilazione. Compili e fai upload, la board si avvia.
Poi devi ricompilare e fare upload SENZA quella riga
Grazie Mille!!
Scusate forse non mi ero spiegato bene.
Grazie
