Problemino con un ciclo for
Ciao ragazzi. Premetto che programmo molto poco. Ho fatto qualcosina da autodidatta ma veramente nulla.
Vi spiego il mio problema:
sto cercando di creare con arduino uno un timer countdown con un display 7 segmenti a 4 cifre, shift register( il 595) e un modulo rotary encoder ky040.
per ora lavoro solo con due cifre.
qui c’è tutto il codice
//encoder
int clkPin= 2;
int dtPin =3;
int encoderVal = 0;
int swPin =4;
int buttonState=0;
int lastButtonState=0;
int count=0;
//74HC595
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
//display
int dig2=6;
int dig1=7;
int num[10] = {129, 207, 146, 134, 204, 164, 160, 143, 128, 132};
//timer
int timer=0;
int dec=0;
int unit=0;
long i=1000;
long old=0;
unsigned long curr=0;
  //encoder
  pinMode(clkPin, INPUT);
  pinMode(dtPin, INPUT);
  pinMode(swPin, INPUT);
  //595
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  //display
  pinMode(dig2,OUTPUT);
  pinMode(dig1,OUTPUT);
  pinMode(10,OUTPUT);
void loop(){
  buttonState=digitalRead(swPin);
  if (buttonState != lastButtonState) {
    if (buttonState == HIGH) {
    count++;
    Serial.println("on");
    Serial.print("numer of button pushes:    ");
    Serial.println(count);
    else {
      Serial.println("off");
    lastButtonState = buttonState;
     //***** encoder set*****
  int change = getEncoderTurn();
    encoderVal = encoderVal + change;
    if(encoderVal<0){
      encoderVal=0;
     if(encoderVal>=99){
      encoderVal=99;
      dec=encoderVal/10;
      unit=encoderVal-(dec*10);
//**************timer set**************
  if(count!=0){
  if(count>1){
      count=0;
     //cifra uno
    digitalWrite(latchPin, LOW);
    shiftOut(dataPin, clockPin, LSBFIRST, num[dec]);
    digitalWrite(latchPin, HIGH);
    digitalWrite(dig1,HIGH);
    delay(1);
    digitalWrite(dig1,LOW);
    //cifra due
    digitalWrite(latchPin,LOW);
    shiftOut(dataPin, clockPin, LSBFIRST, num[unit]);
    digitalWrite(dig2,HIGH);
    delay(1);
    digitalWrite(dig2,LOW);
  //***********timer start**************
    for (timer=encoderVal;timer>=0;timer--){
      dec=timer/10;
      unit=timer-(dec*10);
       while(curr-old<i){
          curr=millis();
     //cifra uno
          delay(1);
    //cifra due
          delay(1);
      old=old+i;
    count=1;
int getEncoderTurn(void)
  static int oldA = HIGH;
  static int oldB = HIGH;
  int result = 0;
  int newA = digitalRead(clkPin);
  int newB = digitalRead(dtPin);
  if (newA != oldA || newB != oldB)
    if (oldA == HIGH && newA == LOW)
      result = (oldB * 2 - 1);
  oldA = newA;
  oldB = newB;
  return result;
il problema è che quando clicco il bottone il timer non parte dal numero che segna sul display ma è come se iniziasse il conto alla rovescia non appena arduino si accende.
Io sinceramente non ho capito. Non mi è chiaro a cosa serve il rotary encoder ?
P.S. nel codice LEVA quelle mille e mille righe vuote che servono a una cippa di nulla !!
se ruoto aumenta o diminuisce il valore del timer. se lo clicco lo fa partire
Ma questo che serve ?
  if(count!=0){
    if(count>1) count=0;
Se count diverso da zero, ma appena vale 2 ridiventa 0 :o
Ogni click che faccio aumenta count di 1: quando è 0 setto il timer, quando è 1 parte il conto alla rovescia.
Sbaglio o nel timer set:
  if(count!=0){
Non azzeri dec e unit ?!
Ho modificato il void loop() in questo modo
void loop(){
    if(encoderVal<0){
      encoderVal=0;
     if(encoderVal>=99){
      encoderVal=99;
      dec=encoderVal/10;
     //cifra uno
    delay(1);
    //cifra due
    delay(1);
  if(digitalRead(swPin)==LOW){
      dec=timer/10;
       while(curr-old<i){
          curr=millis();
     //cifra uno
          delay(1);
    //cifra due
          delay(1);
      old=old+i;
ma il problema rimane. nella mia assoluta ignoranza e disperazione ho aggiunto una riga di codice che alla fine del ciclo for mi azzererebbe il timer
        timer=0;
      dec=timer/10;
       while(curr-old<i){
          curr=millis();
     //cifra uno
          delay(1);
    //cifra due
          delay(1);
        timer=0;
      old=old+i;
adesso non capisco perchè ho risolto il problema, il timer comincia dal momento in cui clicco. Ma vorrei capire il perchè
