Hello everyone,
I am using Arduino Mega 2560 and Redfly Wifi-Shield. I want to send data by serial.write() when i access to the wlan, to communicate with the slave device i have to initialize the serial port, Serial1.begin(38400,0x36), that means 1 startbit, 8 databits, 1 stopbit, odd, but the wifi-shield cant work under this set.
here is my code
#include <RedFly.h>
#include <Serial.h>
uint8_t PLAY[3]={0x20,0x01,0x21};
uint8_t STOP[3]={0x20,0x00,0x20};
byte ip[] = { 192,168, 1,110 }; //ip from shield (server)
byte netmask[] = { 255,255,255, 0 }; //netmask
uint8_t http=INVALID_SOCKET; //socket handle
uint16_t http_len=0; //receive len
char http_buf[64]; //receive buffer
//debugout and debugoutIn will be used to test the communication between Arduino and PC
void debug(char *s)
RedFly.disable();
Serial.print(s);
RedFly.enable();
uint8_t ret;
Serial1.begin(38400,0x36);
//init the WiFi module on the shield
// ret = RedFly.init(br, pwr) //br=9600|19200|38400|57600|115200|200000|230400, pwr=LOW_POWER|MED_POWER|HIGH_POWER
// ret = RedFly.init(pwr) //9600 baud, pwr=LOW_POWER|MED_POWER|HIGH_POWER
// ret = RedFly.init() //9600 baud, HIGH_POWER
ret = RedFly.init();
if(ret)
debug("INIT ERR"); //there are problems with the communication between the Arduino and the RedFly
//scan for wireless networks (must be run before join command)
RedFly.scan();
ret = RedFly.join("redfly","AB12345678",IBSS_CREATOR,2);
if(ret)
debug("JOIN ERR");
for(;;); //do nothing forevermore
ret = RedFly.begin(ip,0,0,netmask);
if(ret)
Serial.println(ret);
RedFly.disconnect();
RedFly.getlocalip(ip); //receive shield IP in case of DHCP/Auto-IP
http = RedFly.socketListen(PROTO_TCP, 80); //start listening on port 80
if(http == 0xFF)
debug("SOCKET ERR");
uint8_t sock;
char buf[512], *ptr;
uint16_t buf_len, rd, len;
//check if socket is opened
if(RedFly.socketClosed(http)) //no socket open
//get data
sock = 0xFF; //0xFF = return data from all open sockets
ptr = buf;
buf_len = 0;
do
rd = RedFly.socketRead(&sock, &len, (uint8_t*)ptr, sizeof(buf)-buf_len);
if((rd != 0) && (rd != 0xFFFF)) //0xFFFF = connection closed
ptr += rd;
buf_len += rd;
}while((len != 0) && (buf_len < sizeof(buf)));
//progress the received data
if(buf_len && (sock == http) && (sock != INVALID_SOCKET))
if(strncmp_P(buf, PSTR("GET / HTTP"), 10) == 0) //main site´
//send HTTP 200 header
RedFly.socketSendPGM(sock, PSTR("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n")); //Content-Length: xx\r\n
RedFly.socketSendPGM(sock, PSTR("<h1>Guten Tag! <h1>
RedFly.socketSendPGM(sock, PSTR(" <a href='/<h1>ledon<h1>'>play</a> - <a href='/<h1>ledoff<h1>'>stop</a>"));
else if(strncmp_P(buf, PSTR("GET /ledon HTTP"), 15) == 0) //led on
//send HTML data
RedFly.socketSendPGM(sock, PSTR("<h1>Hello <h1>
for(;;){
Serial1.write(PLAY,sizeof(PLAY));
if(Serial1.available()>0)
Serial.println("**********************");
Serial.println(Serial1.read(),HEX);
else if(strncmp_P(buf, PSTR("GET /ledoff HTTP"), 16) == 0) //led off
//send HTML data
for(;;){
Serial.write(STOP,sizeof(STOP));
/*if(Serial1.available()>0)
//send HTTP 404 header
RedFly.socketSendPGM(sock, PSTR("HTTP/1.1 404 Not Found\r\n\r\n"));
//close connection
RedFly.socketClose(sock);
could anyone tell me what's the problem?
thanks
