Problems Arduino 33 IoT and Raspberry pi3
Hello everyone!
I am using the raspberry Pi3 to program the arduino nano 33 IoT. When I choose the 33 IoT board I have a problem with the compilation, it indicates the following:
"Detecting libraries used...
/home/pi/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino NANO 33 IoT"" -I/home/pi/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/pi/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /tmp/arduino_build_407916/sketch/Blink.ino.cpp -o /dev/null
Error while detecting libraries included by /tmp/arduino_build_407916/sketch/Blink.ino.cpp
Generating function prototypes...
/home/pi/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10815 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino NANO 33 IoT"" -I/home/pi/.arduino15/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/pi/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /tmp/arduino_build_407916/sketch/Blink.ino.cpp -o /tmp/arduino_build_407916/preproc/ctags_target_for_gcc_minus_e.cpp
/home/pi/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.28' not found (required by /home/pi/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++)
exit status 1
Error compiling for board Arduino NANO 33 IoT."
That error appears when using the blink example for this arduino board. In windows this problem does not occur, and it works normally. On the other hand, if in raspberry I select the arduino uno, it works perfectly. Could you help me? Thank you very much for your attention.
