problems buzzer
Hello. I did a project with an alcohol detector to go very good.And I met him a problem.Il want to add a buzzer to ring only if statement (value> = 200 && value <280), when appearing on LCD. display.println ( “You had a beer.”); , and it does not work. I did something wrong in code? Any answer is welcome. I’m a beginner. This is the code.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
int TIME_UNTIL_WARMUP = 900;
unsigned long time;
int analogPin = 0;
int val = 0;
int buzzer = 10;
Adafruit_SSD1306 display(OLED_RESET);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
pinMode(10,OUTPUT);
delay(100);
val = readAlcohol();
printTitle();
printWarming();
time = millis()/1000;
if(time<=TIME_UNTIL_WARMUP)
time = map(time, 0, TIME_UNTIL_WARMUP, 0, 100);
display.drawRect(10, 50, 110, 10, WHITE); //Empty Bar
display.fillRect(10, 50, time,10,WHITE);
}else
printTitle();
printAlcohol(val);
printAlcoholLevel(val);
display.display();
void printTitle()
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(22,0);
display.println(“Breath Analyzer”);
void printWarming()
display.setTextSize(2);
display.setCursor(0,20);
display.println(“Warming up”);
void printAlcohol(int value)
display.setCursor(45,25);
display.println(val);
void printAlcoholLevel(int value)
display.setCursor(10,55);
if(value<200)
display.println(“You are sober.”);
if (value>=200 && value<280)
display.println(“You had a beer.”);
digitalWrite(10,HIGH);
if (value>=280 && value<350)
display.println(“Two or more beers.”);
if (value>=350 && value <450)
display.println(“I smell Oyzo!”);
if(value>450)
display.println(“You are drunk!”);
int readAlcohol()
int val = 0;
int val1;
int val2;
int val3;
val1 = analogRead(analogPin);
delay(10);
val2 = analogRead(analogPin);
delay(10);
val3 = analogRead(analogPin);
val = (val1+val2+val3)/3;
return val;
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
Where is the value variable given a numeric value ?
What type of buzzer do you have? Should you be using Tone library?
