Problems communicating with SIM800L module and Arduino Mega
I am using this sim800L module:
And a Arduino Mega 2560, I'm connecting them this way since the module's logic is 3.3v and not 5v tolerant:
And I'm just trying to connect with the module via AT commands, I saw a lot of tutorials and they use the SoftwareSerial library even if they are using the Mega with 4 UARTs and if I try it like that it works but I want to connect it in the UART pins.
This is the code I'm using:
  Serial2.begin(9600);
  if (Serial2.available())
    Serial.write(Serial2.read());//Forward what Serial received to Software Serial Port
  if(Serial.available())
    Serial2.write(Serial.read());//Forward what Software Serial received to Serial Port
But when I run it and send "AT" I read this:
Any ideas what may be wrong?
Thank you!
Please post a simple sketch using the SoftwareSerial library that makes it work as expected.
Hi, I can't make it work now with the SoftwareSerial library but I tried this code and it's working but I've also heard that the String class is not good either.
#define gsm Serial2
String Arsp, Grsp;
if(gsm.available())
Grsp = gsm.readString();
Serial.println(Grsp);
Arsp = Serial.readString();
gsm.println(Arsp);
[/code]
That's not a complete sketch.
Yes it is.
No it's not. Please copy the code from your previous reply and try to compile it.
Done. I mean it compiles and if I upload it to the Mega it communicates with the module
