Problems connecting to MQTT with username and password
I'm hoping this is something simple that I'm just not understanding. I'm trying to wrap my mind around both ethernet and mqtt on arduino. I've used them separately, but I can get a lot of raspberry pi's out of the way if I can publish mqtt messages directly from the arduino.
I have a nano with the nano arduino shield. I can publish messages to my local network (192.168.0.222) with no password on port 1883.
I can publish messages to my private server which is on the public internet from a raspberry pi (so I definitely know the password, ip addresses etc).
However, I can't figure out how to publish messages from the arduino when I need a username and password. Here's my local sketch...
#include <UIPEthernet.h>
#include "PubSubClient.h"
#define CLIENT_ID       "BoilerRoom"
#define INTERVAL        15000 // 15 sec delay between publishing
uint8_t mac[6] = {0x00,0x01,0x02,0x03,0x04,0x05};
EthernetClient ethClient;
PubSubClient mqttClient;
long previousMillis;
  // setup serial communication
  // setup ethernet communication using DHCP
  if(Ethernet.begin(mac) == 0) {
    Serial.println(F("Ethernet configuration using DHCP failed"));
    for(;;);
  // setup mqtt client
  mqttClient.setClient(ethClient);
  mqttClient.setServer("192.168.0.222",1883);
  Serial.println(F("MQTT client configured"));
  previousMillis = millis();
  // check interval
  if(millis() - previousMillis > INTERVAL) {
    sendData();
  mqttClient.loop();
void sendData() {
  char msgBuffer[20];
  if(mqttClient.connect(CLIENT_ID)) {
   mqttClient.publish("boilerTemp", "5000");
   Serial.println(F("Attempted to send temp"));
 }else{
     Serial.println(F("Failed"));
Looking at the documentation, I was assuming I could change port 1883 to 8883 and change this line...
to
  if(mqttClient.connect(CLIENT_ID, "myUsername", "myPassword")) {
but that doesn't seem to be working. Can anyone help?
Did you try activating authentication on your local server and sending messages there? I don't know your network, it might be possible that the Arduino isn't able to connect to the remote server (that's necessary before the authentication).
