problems connecting to webclient
I’m completing a greenhouse monitoring project involving taking sensor readings and putting them in a mysql database via php. I’ve been having problems connecting to the php page which I’ve hosed online using azure. The php it self is fine as I can get it to complete an insert operation on the data base by typing the sensor variables in the url. I can successfully configure the Ethernet and I never seem to get a “connection failed” message but it never seems to successfully complete an insert operation. any ideas?
#include <DHT.h>
#include <Ethernet.h>
#include <SPI.h>
DHT dht(2, DHT11);
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0xAB, 0xFE }; // RESERVED MAC ADDRESS
// Set the static IP address to use if the DHCP fails to assign
//IPAddress ip(192,168,1,10);
EthernetClient client;
float temperature;
float reading;
float Lightreading;
float MoistureReading;
float Humidity;
int lm35Pin = 0;
int LightResis = 1;
int MoistureSensor = 3;
String data;
    analogReference(INTERNAL);
    dht.begin();
      if (Ethernet.begin(mac) == 0)
        Serial.println("Failed to configure Ethernet using DHCP");
      data ="";
   reading = analogRead(lm35Pin);
   delay(20);
   temperature = reading / 9.31;
    Lightreading = analogRead(LightResis);
    MoistureReading = analogRead(MoistureSensor);
    delay(20);
  Humidity = dht.readHumidity();
  Humidity = 50;
    Serial.print("Temperature: ");
    Serial.print(temperature);
    Serial.println(" *C");
    Serial.print("Light Intensity: ");
    Serial.println(Lightreading);
    Serial.print("Soil Moisture Content: ");
    Serial.println(MoistureReading);
    Serial.print("Relative Humidity: ");
    Serial.print(Humidity);
    Serial.println(" %\t");
    Serial.println("---------------------------");
  if (client.connect("greenhousedatahandler.azurewebsites.net",80))
      Serial.println("-> Connected");
      client.print("GET /add.php?");
      client.print("Temperature=");
      client.print(temperature);
      client.print("&LightIntensity=");
      client.print(Lightreading);
      client.print("&SoilMoisture=");
      client.print(MoistureReading);
      client.print("&Humidity=");
      client.print(Humidity);
      client.println(" HTTP 1.1");
      client.println("Host: greenhousedatahandler.azurewebsites.net"); // SERVER ADDRESS HERE TOO
      client.println( "Connection: close" );
      client.println();
      client.println();
  //  char c = client.read();
 //   Serial.print(c);
      client.stop();
    // you didn't get a connection to the server:
    Serial.println("--> connection failed/n");
  delay(10000);
Set up a PC with a packet sniffer and see what the difference is between what the Arduino sends and what the browser sends.
for closure I never did manage to get a reply from the php files hosted on azure, in the end I hosted the files off my laptop using wamp server were the arduino accessed them through the router.
