Problems connecting Yun to .local network
After configuring a new Arduino Yun for wifi, I try to connect to “myYunname”.local and the browser starts to connect but stalls and never connects. Any obvious or typical resolution that I may be missing?
Have you tried going to "arduino.local"? Also, look in your router config and see if it is connected (if the router can do that. If not, use a program to do that). If that doesn't work, try uploading YunSerialTerminal. Then, run ifconfig to get the IP. Enter that IP into your browser.
Thank you. This helped. The router configuration page showed the Yun connected however, it had a reserved IP different than 192.168.240.1. So when I typed in that new IP, I was able to access the Yun within the local network. Cheers
