Problems controlling two modified MG996 servos along 3 other servos
I replaced the potentiometer with two 2200Ω resistors, I've tested each one individually and they work, the problem is when I add the rest of the servo, what happens is that servo1 does not respond properly and independently of what value I write it just keeps spinning clockwise at apparently the same speed.
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Servo.h>
RF24 radio(6,7); // CE, CSN
const byte address[6] = "00001";
int msg;
int val1;
int val2;
int val3;
int val4;
int val5;
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
  servo1.attach(1);
  servo2.attach(2);
  servo3.attach(3);
  servo4.attach(4);
  servo5.attach(5);
  servo2.write(85);//These are the modified servos, and with these values they are supposed to stop rotating, atleast they did stop when tested individually
  servo1.write(97);
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.setPALevel(RF24_PA_MIN);
  radio.startListening();
//What I do is send a variable of 4 digits, the first indicates the servo and the remaining the degrees to rotate
  if (radio.available()) {
  radio.read(&msg, sizeof(msg));
  if (msg/1000==1){
    val1= msg-1000;
    //servo1.write(val1);
  }else if (msg/1000==2){
    val2=msg-2000;
    //servo2.write(msg-2000);
  }else if (msg/1000==3){
    val3=msg-3000;
    servo3.write(msg-3000);
  }else if(msg/1000==4){
    val4-msg-4000;
    servo4.write(msg-4000);
  }else if (msg/1000==5){
    val5=msg-5000;
    servo5.write(val5);
  Serial.println(msg);
My only concern with the wiring is the way the connections to the GND and 5V, I attach a pic of what one of these connections looks like, the signal just goes directly to the pin it is assigned to.
  servo1.attach(1);
Pin 1 is the Serial TX pin on most Arduino boards. Which board do you have?
As already said you can't use pin1 both for a servo and for Serial prints.
And that picture is useless. 6 bits of wire connected to nothing and one of them has another unidentified bit of wire plugged into it. But if by any chance you mean that you have 5 servos all powered from the Arduino 5V pin then don't. Servos need to be powered direct from a battery/power supply not from the Arduino.
Steve
maybe the problem is the current needed for servos. Because arduino didnt have much current to supply the motors.
nielyay
I got my Arduinos UNO R3 from this seller on Amazon (https://www.amazon.es/dp/B07BGWS1N7/ref=pe_3310721_189395781_TE_SCE_dp_1), I've rearranged the servo pin, but still keeps spinning only clockwise, now about the voltage, it's a parallel circuit, so shouldn't it be 5V across every servo, I've checked their requirements and they are supposed to work with voltages in between 4.8V and 7V
You must have a separate power supply for the servos, capable of several Amperes at 5-6V.
Connect all the grounds together.
