Hello All,
I'm working with an ATMega32U4 breakout board (the MT-DB-U4 made by MattairTech), which uses the Arduino CDC bootloader. I was working on creating a library which internally creates an instance of the LiquidCrystal library object to control an LCD screen. The library worked greeat, except that I had to put an #include for the LiquidCrystal.h library at the top of the code in the main program in order for the library to function. I also had includes for the LiquidCrystal.h library inside my library's .cpp and .h files so I'm not sure why I also need to put it in the user's program. I did create a simplified example to illustrate the problem I'm seeing. In the below snippets of code, I show the code for the user program, the library's .cpp file and .h file:
User Program:
#include "Class.h"
#include <LiquidCrystal.h> //<-- Program bombs if this is left out
TestClass Class1;
Class1.LCD.print("Hello World");
// Do Nothing
Test Library's Header file
#ifndef Class_H
#define Class_H
#include <Arduino.h>
class TestClass
public:
LiquidCrystal LCD; // LCD Object
TestClass(); // Class Constructor prototype
#endif
Test Library's .cpp file:
#include "Class.h"
TestClass::TestClass()
: LCD(18, 19, 20, 21, 22, 23, 24) // Initialize LCD object
LCD.begin(12, 2); // Start and clear LCD Screen
LCD.clear();
The code in the above example works fine as-is. But if you comment out the "#include <LiquidCrystal.h>" line at the top of the main program, it gives the following error:
In file included from Class.cpp:1:
Class.h:11: error: 'LiquidCrystal' does not name a type
Class.cpp: In constructor 'TestClass::TestClass()':
Class.cpp:5: error: class 'TestClass' does not have any field named 'LCD'
Class.cpp:15: error: 'LCD' was not declared in this scope
I don't want to make the user have to include the LiquidCrystal library external to the library when I already have it included in the library header. Any idea why it is doing this? I did try putting the include inside the library's .cpp file but that didn't seem to work either.
- Jason O
