Hi
I am a newbie to Arduino and having problems getting sketches downloaded. I have been through the troubleshooting guide and have read around the problem but haven't been able to solve. I'm on MacOS 10.11.6 and have an Arduino Uno R2. I get the error message pasted at the end of this post when I try to download a sketch. The board is communicating with my Mac as when I open the Serial Monitor, I get a continuous stream of seemingly random numbers scrolling past. If I disconnect the board, the stream of characters stop. If I select a different baud rate I get the message that there is an error connecting to the serial port, and so my Mac and the board are communicating. Any suggestions would be greatly appreciated.
Eddie
Error Message when downloading a sketch:
Sketch uses 1888 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 188 bytes (9%) of dynamic memory, leaving 1860 bytes for local variables. Maximum is 2048 bytes.
/Users/user/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Users/user/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem1A21 -b115200 -D -Uflash:w:/var/folders/tw/h55xxhgs5yq1c_fw7bt0k9th0000gn/T/arduino_build_782212/AnalogReadSerial.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/user/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/user/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1A21
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 3.3
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/var/folders/tw/h55xxhgs5yq1c_fw7bt0k9th0000gn/T/arduino_build_782212/AnalogReadSerial.ino.hex"
avrdude: writing flash (1888 bytes):
Writing | avrdude: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x00
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x00
###avrdude: stk500_cmd(): programmer is out of sync
ABOVE LINE REPEATED LOTS OF TIMES AND THEN ENDING
avrdude: 1888 bytes of flash written
avrdude: verifying flash memory against /var/folders/tw/h55xxhgs5yq1c_fw7bt0k9th0000gn/T/arduino_build_782212/AnalogReadSerial.ino.hex:
avrdude: load data flash data from input file /var/folders/tw/h55xxhgs5yq1c_fw7bt0k9th0000gn/T/arduino_build_782212/AnalogReadSerial.ino.hex:
avrdude: input file /var/folders/tw/h55xxhgs5yq1c_fw7bt0k9th0000gn/T/arduino_build_782212/AnalogReadSerial.ino.hex contains 1888 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x00
avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0x00
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x00
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
