Hello everyone,
I am trying to fade an RGB led from red, green to amber whilst going to sleep in between transitions. The reason for this is to save power. However I also want the Arduino to wake up for 2s after sleeping for 8s a number of times.
What I want it to do is - Fade to red
- Stay on red and sleep for a number of counts
- Fade to amber
- Stay on amber and sleep for a number of counts
- Fade to green
- Stay on Green and finish
but what its actually doing is - Fade to red
- Fade to amber
- blinks amber when awake and red when sleeping
- Fade to green
#include <avr/sleep.h>
#include <avr/wdt.h>
//Constants that won't change
const int BLUE = 11; // the number of the blue LED
const int GREEN = 10; // the number of the green LED
const int RED = 9; // the number of the red LED
//Constants that will change
int Timerstart = 0; //Check if the light sequence has started or finished
int Timerstage = 1; //At which stage the lighting sequence is at
int SleepCount; //The amount of times the Arduino has slept for
// watchdog interrupt
ISR (WDT_vect)
wdt_disable(); // disable watchdog
} // end of WDT_vect
// initialize the digital pin as an output.
pinMode(BLUE, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(RED, OUTPUT);
Serial.println (SleepCount);
//******************************************************************************************************** RED GREEN AMBER ******************************************************************************************************************************************************
if (Timerstart == 0)
if (Timerstage == 1) {
for (int RVALUE = 0; RVALUE < 255; RVALUE = RVALUE + 1) {
analogWrite(RED, RVALUE); // Increment the red LED voltage value.
delay(10); // Time taken for the brightness to reach 255 (in milliseconds).
Timerstage = 2;
analogWrite(RED, 255); // Stay on Red
if (Timerstage == 2)
while (SleepCount < 3)
MonitorBattery();
LowPowerMode();
if (SleepCount == 3)
Timerstage = 3;
SleepCount = 0;
if (Timerstage == 3) {
for (int GVALUE = 0; GVALUE < 20; GVALUE = GVALUE + 1) {
analogWrite(GREEN, GVALUE); // Increment the green LED voltage value.
delay(40); // Time taken for the brightness to reach 20 (in milliseconds).
Timerstage = 4;
analogWrite(GREEN, 20); // Stay on Green
if (Timerstage == 4)
MonitorBattery();
LowPowerMode();
Timerstage = 5;
SleepCount = 0;
float z = 1.416;
for (int GVALUE = 20, RVALUE = 255; GVALUE<255, RVALUE>0; GVALUE = GVALUE + 1, RVALUE = RVALUE - z) {
analogWrite(RED, RVALUE); // Decrement the red LED voltage value.
delay(10); // Time taken for the brightness to reach 255 and 0 (in milliseconds).
analogWrite(GREEN, 150);
Timerstart = 1;// End of lighting sequence and stay on Green.
//************************************************************************************************************** End of Loop *********************************************************************************************************************************************
void LowPowerMode() { //Sleep during light sequence
// disable ADC
ADCSRA = 0;
// clear various "reset" flags
MCUSR = 0;
// allow changes, disable reset
WDTCSR = bit (WDCE) | bit (WDE);
// set interrupt mode and an interval
WDTCSR = bit (WDIE) | bit (WDP3) | bit (WDP0); // set WDIE, and 8 seconds delay
wdt_reset(); // pat the dog
set_sleep_mode (SLEEP_MODE_PWR_DOWN);
noInterrupts (); // timed sequence follows
sleep_enable();
// turn off brown-out enable in software
MCUCR = bit (BODS) | bit (BODSE);
MCUCR = bit (BODS);
interrupts (); // guarantees next instruction executed
sleep_cpu ();
// cancel sleep as a precaution
sleep_disable();
void MonitorBattery() { //Wakes up for 2s before going to sleep again.
unsigned long startTime = millis();
unsigned long interval = 2000; // 2 seconds
SleepCount = SleepCount + 1;
while (millis() - startTime < interval)
Serial.println("Seep Count"); //Sleep Status Check
I'm assuming its because i cant use PMW during low power so I need away around that?Or it could just be my programming
