hi guys
im trying to generate three different, random, numbers per cycle of the code however i don't understand why i'm getting the outputs i'm getting. To my mind all three of the "TESTs" should give me the same values. instead thy r all different and all unusable due to duplicate values.
Im really more interested in knowing why it is not working as i think it should than simply being told how i should have written the code.
anyway, the questions id like answered are:
- why dose "TEST 1" give the same value for the 1st & 2nd variable?
- why dose "TEST 2" give the same value all variable?
- why is the 1st variable in "TEST 2" always "0"?
- why cant i combine line 15 & 16? like so: "ran[r] = random(0,255);" if i do combine them, i get some crazy numbers!
thanks for the help
int r; //couter forloop random number genereator
int ran[]={};// array containing 3 random numbers
int RedBri[] = {};
int GreenBri[]={};
int BlueBri[]={};
int prox;
randomSeed(analogRead(0)); // generater random value using noise from the analog read pin
for(r=0; r<=2; r++){ //loop to generater 3 random numbers
prox = random(0,255);// generate random number
ran[r] = prox; // stor random number in array
RedBri[0] = ran[0]; // assign random numbers to neopixel value array
GreenBri[0] = ran[1];
BlueBri[0] = ran[2];
Serial.println(" test 1");
Serial.println(ran[0]); //********TEST 1*********
Serial.println(ran[1]); //********TEST 1 ********
Serial.println(ran[2]); //********TEST 1*********
Serial.println(" test 2");
Serial.println(RedBri[0]); //********TEST 2*********
Serial.println(GreenBri[0]); //********TEST 2 ********
Serial.println(BlueBri[0]); //********TEST 2*********
Serial.println(" test 3"); //********TEST 3*********
Serial.println(ran[r]);
Serial.println(" ");
delay (1000);
