I'm really sorry to write but I have a problem that I cannot solve
Starting from the standard libraries for a Joystick I added an analog input from a pot, but I have to trim the signal at around 400 instead of the normal 1023.
I tried to trim it alone, programming the board with just the pot input and it worked... as soon as I add that part into the whole code of the Joystick, even if I use the constrain function, the output goes still from 0 to 1023
Do I probably miss something?
#include <Joystick.h>
Joystick_ Joystick;
 // Initialize Button Pins
 pinMode(9, INPUT_PULLUP);
 pinMode(10, INPUT_PULLUP);
 pinMode(11, INPUT_PULLUP);
 pinMode(12, INPUT_PULLUP);
 pinMode(A0, INPUT);
 // Initialize Joystick Library
 Joystick.begin();
// Constant that maps the phyical pin to the joystick button.
const int pinToButtonMap = 9;
// Last state of the button
int lastButtonState[4] = {0,0,0,0};
{int pot = analogRead(A0);
pot=constrain(pot, 0, 460);
int mapped = map(pot,0,460,0,255);
{Joystick.setThrottle(mapped);}}
 // Read pin values
 for (int index = 0; index < 4; index++)
  int currentButtonState = !digitalRead(index + pinToButtonMap);
  if (currentButtonState != lastButtonState[index])
   Joystick.setButton(index, currentButtonState);
   lastButtonState[index] = currentButtonState;
 delay(50);
