Why do you do a Serial.begin() 8 times? Once is enough
If your code is small enough (maximum post size is around 9kB), please post it in the post using code tags
type
** **[code]** **
paste your code after that
type
** **[/code]** **
after the pasted code
I’ve done it for you; Ive also fixed up the indentations so it’s easier to read. Use tools → autoformat (or T) for that before posting code.
matrixMpxAnimation sketch
animates two heart images to show a beating heart
// the heart images are stored as bitmaps - each bit corresponds to an LED
// a 0 indicates the LED is off, 1 is on
byte P4[] =
B01010,
B10101,
B10001,
B01010,
B00100
byte dw[] =
B00000,
B00000,
B11111,
B00000,
B00000
byte op[] =
B00100,
B00100,
B00100,
B00100,
B00100
byte fs[] =
B00001,
B00010,
B00100,
B01000,
B10000
byte bs[] =
B10000,
B01000,
B00100,
B00010,
B00001
byte A[] =
B00100,
B01010,
B11111,
B10001,
B10001
byte B[] =
B11110,
B10001,
B11110,
B10001,
B11110
byte C[] =
B11111,
B10000,
B10000,
B10000,
B11111
byte D[] =
B11110,
B10001,
B10001,
B10001,
B11110
byte E[] =
B11111,
B10000,
B11110,
B10000,
B11111
byte F[] =
B11111,
B10000,
B11100,
B10000,
B10000
byte G[] =
B11111,
B10000,
B10011,
B10001,
B01110
byte H[] =
B10001,
B10001,
B11111,
B10001,
B10001
byte I[] =
B01110,
B00100,
B00100,
B00100,
B01110
byte J[] =
B11111,
B00001,
B00001,
B10001,
B01110
byte K[] =
B10001,
B10010,
B10100,
B11010,
B10001
byte L[] =
B10000,
B10000,
B10000,
B10000,
B11110
byte M[] =
B01010,
B10101,
B10101,
B10001,
B10001
byte N[] =
B10001,
B11001,
B10101,
B10011,
B10001
byte O[] =
B01110,
B10001,
B10001,
B10001,
B01110
byte P[] =
B11110,
B10001,
B11110,
B10000,
B10000
byte Q[] =
B01110,
B10001,
B10101,
B01110,
B00100
byte R[] =
B11110,
B10001,
B11110,
B10001,
B10001
byte S[] =
B01111,
B10000,
B01110,
B00001,
B11110
byte T[] =
B11111,
B00100,
B00100,
B00100,
B00100
byte U[] =
B10001,
B10001,
B10001,
B10001,
B01110
byte V[] =
B10001,
B10001,
B10001,
B01010,
B00100
byte W[] =
B10001,
B10001,
B10101,
B10101,
B01010
byte X[] =
B10001,
B01010,
B00100,
B01010,
B10001
byte Y[] =
B10001,
B01010,
B00100,
B00100,
B00100
byte Z[] =
B11111,
B00010,
B00100,
B01000,
B11111
byte n1[] =
B00100,
B01100,
B10100,
B00100,
B11111
byte n2[] =
B01100,
B10010,
B00100,
B01000,
B11111
byte n3[] =
B01110,
B10001,
B00110,
B10001,
B01110
byte n4[] =
B00110,
B01010,
B11111,
B00010,
B00010
byte n5[] =
B11111,
B10000,
B11110,
B00001,
B11110
byte n6[] =
B01110,
B10000,
B11110,
B10001,
B01110
byte n7[] =
B11111,
B00010,
B00100,
B01000,
B10000
byte n8[] =
B01110,
B10001,
B01110,
B10001,
B01110
byte n9[] =
B00111,
B01001,
B00111,
B00001,
B00001
byte n0[] =
B01110,
B11001,
B10101,
B10011,
B01110
byte P5[] =
B01010,
B00000,
B10001,
B10001,
B01110
byte P1[] =
B10101,
B10101,
B10101,
B00000,
B10101
byte P2[] =
B00000,
B00100,
B00000,
B00100,
B00000
byte P3[] =
B00000,
B00100,
B00000,
B00100,
B00000
const int columnPins[] = { 9, 10, 11, 12, 13};
const int rowPins[] = { 8, 7, 6, 5, 4};
int incomingByte;
for (int i = 0; i < 8; i++)
pinMode(rowPins[i], OUTPUT); // make all the LED pins outputs
pinMode(columnPins[i], OUTPUT);
digitalWrite(columnPins[i], HIGH); // disconnect column pins from Ground
// see if there's incoming serial data:
if (Serial.available() > 0)
// read the oldest byte in the serial buffer:
incomingByte = Serial.read();
// if it's an L (ASCII 76) turn off the LED:
if (incomingByte == 'A')
show(A, 500);
if (incomingByte == 'B')
show(B, 500);
if (incomingByte == 'C')
show(C, 500);
if (incomingByte == 'D')
show(D, 500);
if (incomingByte == 'E')
show(E, 500);
if (incomingByte == 'F')
show(F, 500);
if (incomingByte == 'G')
show(G, 500);
if (incomingByte == 'H')
show(H, 500);
if (incomingByte == 'I')
show(I, 500);
if (incomingByte == 'J')
show(J, 500);
if (incomingByte == 'K')
show(K, 500);
if (incomingByte == 'L')
show(L, 500);
if (incomingByte == 'M')
show(M, 500);
if (incomingByte == 'N')
show(N, 500);
if (incomingByte == 'O')
show(O, 500);
if (incomingByte == 'P')
show(P, 500);
if (incomingByte == 'Q')
show(Q, 500);
if (incomingByte == 'R')
show(R, 500);
if (incomingByte == 'S')
show(S, 500);
if (incomingByte == 'T')
show(T, 500);
if (incomingByte == 'U')
show(U, 500);
if (incomingByte == 'V')
show(V, 500);
if (incomingByte == 'W')
show(W, 500);
if (incomingByte == 'X')
show(X, 500);
if (incomingByte == 'Y')
show(Y, 500);
if (incomingByte == 'Z')
show(Z, 500);
if (incomingByte == '0')
show(n0, 500);
if (incomingByte == '1')
show(n1, 500);
if (incomingByte == '2')
show(n2, 500);
if (incomingByte == '3')
show(n3, 500);
if (incomingByte == '4')
show(n4, 500);
if (incomingByte == '5')
show(n5, 500);
if (incomingByte == '6')
show(n6, 500);
if (incomingByte == '7')
show(n7, 500);
if (incomingByte == '8')
show(n8, 500);
if (incomingByte == '9')
show(n9, 500);
if (incomingByte == ' ')
delay(400);
if (incomingByte == '!')
show(P1, 500);
if (incomingByte == '&')
show(P5, 500);
if (incomingByte == '-')
show(dw, 500);
if (incomingByte == '|')
show(op, 500);
if (incomingByte == '/')
show(fs, 500);
if (incomingByte == '<')
show(bs, 500);
if (incomingByte == '%')
show(P4, 500);
if (incomingByte == ':')
show(P2, 500);
if (incomingByte == ';')
show(P3, 500);
if (incomingByte == 'a')
show(O, 500); show(W, 500); delay(400);
show(Y, 500); show(E, 500); show(S, 500);
// routine to show a frame of an image stored in the array pointed to by the image parameter.
// the frame is repeated for the given duration in milliseconds
void show( byte * image, unsigned long duration)
unsigned long start = millis(); // begin timing the animation
while (start + duration > millis()) // loop until the duration period has passed
for (int row = 0; row < 5; row++)
digitalWrite(rowPins[row], HIGH); // connect row to +5 volts
for (int column = 0; column < 5; column++)
boolean pixel = bitRead(image[row], column);
if (pixel == 1)
digitalWrite(columnPins[column], LOW); // connect column to Gnd
delayMicroseconds(300); // a small delay for each LED
digitalWrite(columnPins[column], HIGH); // disconnect column from Gnd
digitalWrite(rowPins[row], LOW); // disconnect LEDs
