I am a newbie, probably the source of my problems. I wish to use the MLX90614 IR temp sensor for a project that will require reprogramming it. I had no luck doing that so moved to a simpler task to learn to use the I2c interface, r/w to the 24LC256 using the sketch from the youtube humanHardDrive video. I can't even get that code compiled.
So to the question: do the wire and/or the i2cmaster libraries work with the Arduino Uno? If I at least know wire.h works with the Uno, I can beat on it for a while....
I have a Uno and use the wire library often. Never had a problem that was not related to a wrong address, lack of pullups or just bad code. Post your code and any errors that the IDE spits out and we can help.
Thank you both for the quick responses. I'll go back and put the code in line by line and try to work it out. I learn more quickly by experience than by using another's code but I'll probably be back. Just knowing wire.h works with the Uno gives me a lot more confidence.
