Problems of compability
Hi guys,
how can I read a signal, code it in PCM and the see this signal as output of the DAC. This is what I have so far.
and the result is really bad.
ARDUINO NANO + DAC MCP4901
Anykind of help would be really helpfull.
NECESSARIO METTERE NEL PIN DI USCITA UN FILTRO ANTIALIASING RC NEL NOSTRO CASO I VALORI SONO 33OHM E 10NF IL SEGNALE é MISURATO PRIMA DEL FILTRO COME SE FOSSE IL FILTRO UN PULL DOWN;
SEGNALE R POI C.
#include <SPI.h>         // Remember this line!
#include <DAC_MCP49x1.h>
#define SS_PIN 10
DAC_MCP49x1 dac(DAC_MCP49x1::MCP4901, SS_PIN );
// The Arduino pin used for the slave select / chip select
int  i;
unsigned int x, y;
float accum, fval = .20;    // these are variables for a simple low-pass (smoothing) filter - fval of 1 = no filter - .001 = max filter
long fout;
int period = 33;
byte sineovertones[] = {87,-25,110,-127,55,-23,-4, 25,-101,127};
byte sine[] = {0, 22, 44, 64, 82, 98, 111, 120, 126, 128, 126, 120, 111, 98, 82, 64, 44, 22, 0, -22, -44, -64, -82, -98, -111, -120, -126, -128, -126, -120, -111, -98, -82, -64, -44, -22};
//a simple sine wave with 36 samples
int analog0 = 1000; //variable used to store analog input pin 0
byte speakerpin = 3;  //audio playback on pin 3.  This can also be set to pin 11.
volatile byte waveindex = 0; //index variable for position in waveform array Sine[]
volatile byte currentvalue = 0;
Serial.begin(57600);
dac.setSPIDivider(SPI_CLOCK_DIV32);
dac.setPortWrite(true);
 dac.setGain(2);
/************************** PWM audio configuration ****************************/
// Configures PWM on pins 3 and 11 to run at maximum speed, rather than the default
// 500Hz, which is useless for audio output
pinMode(3,OUTPUT); //Speaker on pin 3
cli(); //disable interrupts while registers are configured
bitSet(TCCR2A, WGM20);
bitSet(TCCR2A, WGM21); //set Timer2 to fast PWM mode (doubles PWM frequency)
bitSet(TCCR2B, CS20);
bitSet(TCCR2B, CS21);
bitClear(TCCR2B, CS22);
/* set prescaler to /1 (no prescaling).  The timer will overflow every
*  62.5nS * 256ticks = 16uS, giving a PWM frequency of 62,500Hz, I think.   */
sei(); //enable interrupts now that registers have been set
/************************* Timer 1 interrupt configuration *************************/
bitClear(TCCR1A, COM1A1);
/* Normal port operation, pins disconnected from timer operation (breaking pwm).
*  Should be set this way by default, anyway. */
bitClear(TCCR1A, WGM10);
bitClear(TCCR1A, WGM11);
bitSet(TCCR1B, WGM12);
bitClear(TCCR1B, WGM13);
/* Mode 4, CTC with TOP set by register OCR1A.  Allows us to set variable timing for
*  the interrupt by writing new values to OCR1A. */
bitSet(TCCR1B, CS10);
bitClear(TCCR1B, CS11);
bitSet(TCCR1B, CS12);
/* set the clock prescaler to /8.  Since the processor ticks every 62.5ns, the timer
*  will increment every .5uS.  Timer 1 is a 16-bit timer, so the maximum value is 65536,
*  Giving us a theoretical range of .5us-32.7mS.  There are 48 samples, so the
*  theoretical frequency range is 41.7KHz - .635Hz, which neatly covers the audio
*  spectrum of 20KHz-20Hz.  Theoretical, because I wouldn't recommend actually calling
*  the Timer1 interrupt every .5uS :)  */
bitClear(TCCR1C, FOC1A);
bitClear(TCCR1C, FOC1B);
/* Disable Force Output Compare for Channels A and B, whatever that is.
*  Should be set this way by default anyway. */
OCR1A = 1000;
/* Initializes Output Compare Register A at 32,8ç, so a match will be generated every
*  62.5nS * 32 * 1000 = , for a 1/(80uS*10) = 50Hz tone. */
bitClear(TIMSK1, ICIE1); //disable input capture interrupt
bitClear(TIMSK1, OCIE1B); //disable Output Compare B Match Interrupt
bitSet(TIMSK1, OCIE1A); //enable Output Compare A Match Interrupt
bitClear(TIMSK1, TOIE1); //disable Overflow Interrupt Enable
}//end setup()
ISR(TIMER1_COMPA_vect) {
/* timer1 ISR.  Every time it is called it sets
*  speakerpin to the next value in Sine[].  frequency modulation is done by changing
*  the timing between successive calls of this function, e.g. for a 1KHz tone,
*  set the timing so that it runs through Sine[] 1000 times a second. */
if (waveindex > 9) { //reset waveindex if it has reached the end of the array
  waveindex = 0;
analogWrite(speakerpin, sineovertones[waveindex] + 128);
//analogWrite(speakerpin, sine[waveindex]);
waveindex++;
OCR1A = period;
} //end Timer1 ISR
analog0 = analogRead(0) + 4;
Serial.println(analog0);
 y = 0;        // clear out variables
 x = 0;
 for (i=0; i < 4 ; i++ ){       // do it four times to build up an average - not really neccessary but takes out some jitter
   // LOW-to-HIGH transition
   digitalWrite(8, HIGH);
   // output pin is PortB0 (Arduino 8), sensor pin is PortB1 (Arduinio 9)
   while ((PINB & B100) != B100 ) {        // while the sense pin is not high
     //  while (digitalRead(9) != 1)     // same as above port manipulation above - only 20 times slower!
     x++;
   delay(1);
   //  HIGH-to-LOW transition
   digitalWrite(8, LOW);
   while((PINB & B100) != 0 ){            // while pin is not low  -- same as below only 20 times faster
     // while(digitalRead(9) != 0 )      // same as above port manipulation - only 20 times slower!
     y++;
   delay(1);
 fout =  (fval * (float)x) + ((1-fval) * accum);  // Easy smoothing filter "fval" determines amount of new data in fout
 accum = fout;
period = constrain(fout / 3, 50, 500);
Serial.println(period);
  dac.output(sineovertones[waveindex]);
}//end loop()
Sounds terrible.
What result? In what way is it bad? What did you expect? What did you get?
the result is the output of the DAC.
I am reading a sinewave in analog input A0. and the output of the DAC is a square wave with differentamplitude. HOw can I post a picture of it.
I mean. SIGNAL - ADC - DIGITAL - DAC - SIGNAL is not that write?
I am aspecting to see again my original signal.
Well, you could consider attaching a picture to your post.
I need to upload them somewhere on interenet first?
what I am reading with analog A0
What I am converting in PCM
Output of the DAC
byte doesn't cover your range.
add 128 to all numbers. deal with numbers >255
