problems programming attiny84 using Mega1280 as ISP
I’m trying to follow these instructions:
(basically the MIT H/L Tech Group instructions that appear to be popular).
I am running Arduino IDE from the Ubuntu software repos, I’ve taken into account that when a Mega is used the pins are 50-53 rather than 10-13, and I am using a 10uF capacitor between GND and RESET. I cannot seem to get my Attiny84 to run the blink example.
I am getting the following error repeatedly:
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny84
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x11
avrdude: stk500_cmd(): programmer is out of sync
Any advice is appreciated. If I’ve left anything out that would be useful, please let me know.
Please post verbose output.
avrdude: Version 5.11.1, compiled on Oct 30 2011 at 10:41:10
         System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
         User configuration file is "/home/kent/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATtiny84
         Chip Erase delay              : 4500 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     6     4    0 no        512    4      0  4000  4500 0xff 0xff
           flash         65     6    32    0 yes      8192   64    128  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [14] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] @ [40] . [02] . [00] . [00] . [00]   [20] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Recv: . [1e]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
avrdude: Recv: . [93]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
avrdude: Recv: . [0c]
################################## | 100% 0.12s
avrdude: Device signature = 0x1e930c
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: Send: V [56] . [a0] . [01] . [fc] . [00]   [20]
avrdude: Recv: . [ff]
avrdude: Send: V [56] . [a0] . [01] . [fd] . [00]   [20]
avrdude: Send: V [56] . [a0] . [01] . [fe] . [00]   [20]
avrdude: Send: V [56] . [a0] . [01] . [ff] . [00]   [20]
avrdude: erasing chip
avrdude: Send: V [56] . [ac] . [80] . [00] . [00]   [20]
avrdude: reading input file "/tmp/build679059399535127256.tmp/Blink_Attiny84.cpp.hex"
avrdude: writing flash (806 bytes):
Writing | avrdude: Send: U [55] . [00] . [00]   [20]
avrdude: Send: d [64] . [00] @ [40] F [46] * [2a] . [c0] 9 [39] . [c0] 8 [38] . [c0] 7 [37] . [c0] 6 [36] . [c0] 5 [35] . [c0] 4 [34] . [c0] 3 [33] . [c0] 2 [32] . [c0] 1 [31] . [c0] 0 [30] . [c0] H [48] . [c0] . [2e] . [c0] - [2d] . [c0] , [2c] . [c0] + [2b] . [c0] * [2a] . [c0] . [00] . [00] : [3a] . [00] 7 [37] . [00] . [00] . [00] ; [3b] . [00] 8 [38] . [00] . [00] . [00] 9 [39] . [00] 6 [36] . [00] . [01] . [01] . [01] . [01] . [01] . [01] . [01] . [01] . [02] . [02] . [02] . [01]   [20]
avrdude: Recv: . [11]
avrdude: Send: V [56] @ [40] . [00] . [00] * [2a]   [20]
avrdude: Recv: . [15]
Some stuff at the very top (appeared in white text in the output) of that was omitted due to the character limit. That was the result of enabling verbose upload.
Indicates that the "programmer" (your Mega running the ArduinoISP sketch) is able to communicate with the "target" (the ATtiny84). That's a good thing.
Indicates the the receive buffer in the "programmer" has been overrun. The usual culprit is this line of code which can be removed (the LED will no longer blink during programming). These may also help... http://forum.arduino.cc/index.php?topic=89579.0 http://amanica.blogspot.com/2011/11/my-quest-to-program-attiny85-with-my.html
The other possibility is the toolset (avr gcc version). This may help... http://forum.arduino.cc/index.php?topic=76138.0
