I need using this code, and this code is working, but I want send my Temperature readings to serial monitor each second, I do not know much about programming, so I need your help to understand how I can make this, thanks.
the code is:
#include <OneWire.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS D4
const int relayPin = D1;
const int led = 13;
int sensorValue;
// Configuração do sensor de temperatura
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature DS18B20(&oneWire);
// Colocar o usuário e senha da rede pra ele poder conectar
const char* ssid = "VIVO-CB35";
const char* password = "J608167085";
ESP8266WebServer server(80);
char temperatureString[6];
float getTemperature() {
float temp;
do {
DS18B20.requestTemperatures();
temp = DS18B20.getTempCByIndex(0);
delay(100);
} while (temp == 85.0 || temp == (-127.0));
return temp;
void setup(void){
pinMode(relayPin, OUTPUT);
WiFi.begin(ssid, password);
Serial.println("");
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
// Toda essa parte abaixo é pra geração da página web
server.on("/", {
float temperature = getTemperature();
dtostrf(temperature, 2, 2, temperatureString);
String title = "Temperature";
String cssClass = "mediumhot";
// Testa pra saber se ta frio ou quente
if (temperature < 20)
cssClass = "cold";
else if (temperature > 20)
cssClass = "hot";
// Parte pra gerar a página de internet
String message = "" + title + "<meta charset="utf-8" /><meta name="viewport" content="width=device-width" /><link href='https://fonts.googleapis.com/css?family=Advent+Pro' rel="stylesheet" type="text/css">\n";
message += "html {height: 100%;}";
message += "div {color: #fff;font-family: 'Advent Pro';font-weight: 400;left: 50%;position: absolute;text-align: center;top: 50%;transform: translateX(-50%) translateY(-50%);}";
message += "h2 {font-size: 90px;font-weight: 400; margin: 0}";
message += "body {height: 100%;}";
message += ".cold {background: linear-gradient(to bottom, #7abcff, #0665e0 );}";
message += ".mediumhot {background: linear-gradient(to bottom, #81ef85,#057003);}";
message += ".hot {background: linear-gradient(to bottom, #fcdb88,#d32106);}";
message += "<body class="" + cssClass + "">
" + title + "
" + temperatureString + " °C
server.send(200, "text/html", message);
// Inicia o servidor
server.begin();
// Avisa que ele foi iniciado
Serial.println("Temperature web server started!");
void loop(void){
server.handleClient();
// Se quiser colocar a temperatura pra ser apresentada na saída serial tem que colocar a leitura no loop.
