Problems reading Anemometer
I’m triying to read values from an anemometer. I was using this code in UNO board, but I move my project to MKR. the problem is qhen I compiled the code but give me some errors in interrupts.
#include <math.h>
#define WindSensorPin (5) // The pin location of the anemometer sensor
volatile unsigned long Rotations; // cup rotation counter used in interrupt routine
volatile unsigned long ContactBounceTime; // Timer to avoid contact bounce in interrupt routine
float WindSpeed; // speed miles per hour
  pinMode(WindSensorPin, INPUT);
  attachInterrupt(digitalPinToInterrupt(WindSensorPin), isr_rotation, FALLING);
  Serial.println("Davis Wind Speed Test");
  Serial.println("Rotations\tMPH");
  Rotations = 0;  // Set Rotations count to 0 ready for calculations
  sei();          // Enables interrupts
  delay (3000);   // Wait 3 seconds to average
  cli();          // Disable interrupts
  /* convert to mp/h using the formula V=P(2.25/T)
     V = P(2.25/3) = P * 0.75 */
  WindSpeed = Rotations * 0.75;
  Serial.print(Rotations); Serial.print("\t\t");Serial.println(WindSpeed);
// This is the function that the interrupt calls to increment the rotation count
void isr_rotation () {
  if ((millis() - ContactBounceTime) > 15 ) { // debounce the switch contact.
    Rotations++;
    ContactBounceTime = millis();
Does anybody played with anemometer and MKR boards? any idea what I’m doing wrong?
thank’s
Eduard
What are you actually using as the source of the anemometer ?
Some have a specific voltage requirement and the MKR is a 3.3 volt based board as opposed to the UNO which is a 5 volt board.
Readings need to be accounted for that difference and sensors need to be compliant in that area.
