Problems receiving data from the HC-06 Bluetooth module, sending data works.
I'm trying to use a HC-06 Bluetooth module with an UNO to send a number on my phone to set a target temperature on the UNO whilst also monitoring the temperature measured by the UNO. I have encountered problems receiving the data from my phone.
I have used some code (below) to strip the communications back to basic, but I still can't receive any data, however the sending of the data from the serial port to the phone works fine. I'm using a Serial Bluetooth app on my phone at the moment. I have also got a 3.3-->5V logic level shifter which both the Tx and Rx lines go through to make them the correct level.
I have tried using different pins for the Bluetooth software serial, and also tried using the hardware serial (with different code) but no success. I've also tried using different pins on the bi-directional logic level shifter.
Any insight into why it isn't working would be greatly appreciated, thanks :slight_smile:
#include <SoftwareSerial.h>
#define rxPin 2                          // define SoftwareSerial rx data pin
#define txPin 3                          // define SoftwareSerial tx data pin
SoftwareSerial blueTooth(rxPin, txPin);  // create instance of SoftwareSerial
  Serial.begin(9600);                   // Start hardware Serial
  blueTooth.begin(9600);                // Start SoftwareSerial
    char c;
     if (Serial.available())
       c = Serial.read();
       Serial.print(c);                 // Write the character to the Serial Monitor
       blueTooth.write (c);             // Write the character to Bluetooth
     if (blueTooth.available())
       c = blueTooth.read();
I should also point out this code isn't mine, but from Neil Kenyon's blog
Have you cross connected the RX TX pins.
Pin2 the software serial Rx should be connected to the module Tx pin and Pin 3 the software serial Tx pin should be connected to the module Rx pin.
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
...R
