Problems sending data to a Web Sever with POST method
Hello, i'm trying to send data from an Arduino UNO to a MySQL database in my web. I'm connecting to the internet with the GSM Shield using a SIM card from my country ( not the one included with the shield from Telefonica) and it connects perfectly.
In this sketch i'm using a switch button to input data, the idea is to send every 10 seconds the state of the button (0 or 1) to the server and store it in a database.
Right now the sketch connects to the server, sends data and this data is stored in the database, but there are two problems:
1)The information stored in the database is always 0, no matter what state the button has. Maybe there is something wrong in the HTTP request that i dont see.
2)The connection with the server is succesful the first time, then it fails to connect everytime ( every 10 seconds).
This is the .ino file in the Arduino:
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER "number"
// APN data
#define GPRS_APN       "apn.name" // replace your GPRS APN
#define GPRS_LOGIN     "user"    // replace with your GPRS login
#define GPRS_PASSWORD  "psw" // replace with your GPRS password
// initialize the library instance
GSMClient client;
GPRS gprs;
GSM gsmAccess;
// URL, path & port
char server[] = "mywebsite.com";
char path[] = "/data_process.php";
int port = 80; // port 80 is the default for HTTP
//Example Button
int Boton = 4;
//The variable that will have the data as a string to send it, i read sending an int with POST may cause trouble
String txtBoton="";
void setup(){
  // initialize serial communications and wait for port to open:
  //Establish pin 4 as an INPUT
  pinMode(Boton, INPUT);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Starting Arduino Web Client.");
  // connection state
  boolean notConnected = true;
  // After starting the modem with GSM.begin()
  // attach the shield to the GPRS network with the APN, login and password
  while(notConnected)
    if((gsmAccess.begin(PINNUMBER)==GSM_READY) &
      (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)==GPRS_READY)){
      notConnected = false;
      } else
      Serial.println("Not connected");
  Serial.println("connecting...");
void loop(){
  int estadoBoton = digitalRead(Boton);
  //print the state of the button in the Monitor Serial
  Serial.println(estadoBoton);
  //convert the button state in string to send it
  //Estado_Boton is the variable that the POST method will search for
  txtBoton= "Estado_Boton="+(String(estadoBoton));
  // if you get a connection, report back via serial:
  if (client.connect(server, port))
    Serial.println("conected and sending data");
    // Make a HTTP request:
    client.print("POST ");
    client.print(path);
    client.println(" HTTP/1.1");
    client.print("Host: ");
    client.println(server);
    client.println("Connection: close");
    client.print("Content-Type: application/x-www-form-urlencoded\n");
    client.print("Content-Length: ");
    //PHP page needs to know how many characters the data has
    client.println(txtBoton.length());
    client.print("\n\n");
    //finally the data that is being send to the server
    client.print(txtBoton);
    //Just to know what i am sending
    Serial.print("Variable: ");
    Serial.println(txtBoton);
    Serial.print("Variable Length: ");
    Serial.print(txtBoton.length());
    // if you didn't get a connection to the server:
    Serial.println("the connection failed");
    Serial.print("");
  delay(10000); // delay to send data every 10 seconds
This is the data_process.php file
<?php
$conex = mysql_connect("localhost", "root", "");
if(!$conex){
    die("Atención, no fue posible conectarse con el servidor
".mysql_error());
$db = mysql_select_db("prueba_arduino", $conex);
if(!$db){
    die("Atención, no fue posible conectarse con la base de datos
".mysql_error());
$Estado_Boton = $_POST["Estado_Boton"];
$sql = "INSERT INTO tabla_arduino (Estado_Boton) VALUES ('$Estado_Boton') ";
$res = mysql_query($sql, $conex);
The MySQL database prueba_arduino has a table called tabla_arduino, in this table there are 2 columns.
First one is ID which is the primary key, tinyint, length/set=3, unsigned, NotNull, Autoincrement.
The second one is Estado_Boton which is a tinyint, length/set=3, default=Null, Unsigned.
This is what the Monitor Serial shows:
connecting...
1
Variable: Estado_Boton=1
Variable Length: 14
1
Obviously only the first one was entered into the database but with 0 as it's value.
The connection then continues to fail every 10 seconds and never connects again.
I've tried changing txtBoton= "Estado_Boton="+(String(estadoBoton)); to txtBoton= "Estado_Boton=4"; in the .ino file with no success, it continued to be 0 the value stored in the database.
If anyone could help I would be very grateful.
Thanks in advance, Leo.
String txtBoton="";
No, it won't. It will uselessly piss resources away wrapping a string in a String. String and string are not the same thing.
Two carriage returns in a row indicate the end of the POST data. You have three, and then the data.
Is there really something about the data that is so secret that a GET request, which is far simpler, wouldn't be more reasonable?
Great!! That worked, thank you very much. Now the data is being send perfectly, but the problem of disconnecting continues.
I tried changing in the HTTP request "Connection: close" to "Connection: keep-alive" and still did not work.
I tried starting the GSM modem and attaching the shield to the GPRS network in every loop but it did not work either.
It always connects the first time, sends the data and then just fails to connect.
Thanks in advance for your time, Leo.
Hi, did you ever fix this disconnecting issue?
Also, PaulS stated 2 issues:
  1. That you were using String instead of string, or at least that is what is read like in the post. But I dont see string being a keyword for variable type.
  2. He states that you have 3 carriage returns \n\n but I only see 2.
Did these things have anything to do with the error you were getting?
A string is a NULL terminated array of chars. It is NOT a separate type.
Do you know what println does?
Oh ok, so it was taking a blank string and wrapping it into a null-terminated array?
Yes, println prints to the serial monitor, or something like that, right? Does it automatically print a carriage return, in which case the implicit carriage return would make the 3rd return you were referring to?
Yes, it does.
