So im building a system wich recieves 10 bytes of data from a robotic cameraplatform every 33 milliseconds. The data is read from a serial port and then processed and sent as String via another serial port to a nextion display.
The problem is as soon as i try to send more than 2 Strings in a single loop, the data recieved by the display is screwed up and wrong. Anyone knows why this is?
I use the following code, and yes i know the variable calculations are uggly as shit...
Serial1.begin (2400);
Serial1.flush();
if (Serial1.available()>10)
int inData[10];
int i=0;
for (i=0; i<=9; i++)
inData*=Serial1.read();*
int azLSB = inData[0];*
int azMSB = inData[1];*
int elLSB = inData[2];*
int elMSB = inData[3];*
int styrning =inData[8];*
String styr;*
unsigned int azTemp = (azMSB<<8) | azLSB;*
unsigned int elTemp = (elMSB<<8) | elLSB;*
long azTemp2 = azTemp-32768;*
long elTemp2 = elTemp-32768;*
float faktor = (360.000/65536.000);*
_ float azTemp3 = (azTemp2 * faktor);_
_ float elTemp3 = (elTemp2 * faktor);_ -
float azNextion = -azTemp3;*
float elNextion = elTemp3;*
String stringAz =String(azNextion,3);*
String stringEl = String(elNextion,3);*
if (styrning == 1)*
styr = ("Joystick");*
if (styrning == 2)*
styr = ("Radar");*
if (styrning == 3)*
styr = ("UNIPOS");*
if (styrning == 4)*
styr = ("Prediktor");*
Serial.print("t2.txt=");*
Serial.print(""");*
Serial.print(stringAz);*
Serial.print(""");*
Serial.write(0xFF);*
Serial.print("t3.txt=");*
Serial.print(""");*
Serial.print(stringEl);*
Serial.print(""");*
Serial.print("t4.txt=");*
Serial.print(""");*
Serial.print(styr);*
Serial.print(""");*
Serial.write(0xFF); *
