Problems sending strings with virtualwire and easy transfer
So the Jist of this code for the sake of understanding. We have a costume club who's regions are defined into clans, and each member has their own official member number.
There's a keypad hooked up to the transmitting arduino. When they enter a number and hit the pound sign, I'm trying to send that user's clan, number, and the command they entered.
I know all my code and hardware is correct because I'm sending the member number as an int and I'm receiving it correctly. but I can't seem to figure out how to send a string.
The serial result on the receiver is:
GOT DATA
1147
So obviously it's working, just having some issue with the CLAN string char conversion or something maybe?
anyway I've been at this all weekend and I'm stumped. Any help / assistance you guys can provide would be greatly appreciated! thanks!
Transmitting code:
#include <Keypad.h>
#include <VirtualWire.h>
#include <EasyTransferVirtualWire.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //four columns
char CLAN[] = "BKMG";
int OM = 1147;
char Array[20];
//define the cymbols on the buttons of the keypads
String command = "";
char hexaKeys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = {9, 11, 10, 12}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6,7, 8}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
EasyTransferVirtualWire ET;
struct commandPulse
  char *clan;
  int memberNumber;
  char *command;
commandPulse pulse;
void setup(){
  ET.begin(details(pulse));
 vw_set_tx_pin(4);
  vw_set_ptt_inverted(true);
    // Initialize the IO and ISR
    vw_setup(2000); // Bits per sec
  pinMode(13, OUTPUT);
  randomSeed(analogRead(0));
void sendPulse() {
pulse.clan = CLAN;
pulse.memberNumber = OM;
Serial.println(pulse.clan);
  ET.sendData();
 // pulse.clan = "";
  command = "";
void loop(){
  char customKey = customKeypad.getKey();
 // if (customKey){
 //   Serial.println(customKey);
if (customKey) {
  if (customKey == '#') {
    sendPulse();
    command = command + customKey;
    Serial.println("Pulse is");
    Serial.println(command);
receiving code:
struct commandPulse
  char *clan;
  int memberNumber;
  char *command;
commandPulse message;
//byte message[90]; // a buffer to store the incoming messages
//byte messageLength = 90; // the size of the message
    ET.begin(details(message));
    Serial.println("Device is ready");
    vw_set_ptt_inverted(true); // Required for DR3100
    vw_set_tx_pin(11);
    vw_rx_start(); // Start the receiver
 // commandPulse message;
  if (ET.receiveData()) {
Serial.println("GOT DATA");
    Serial.println(message.clan);
    Serial.println(message.memberNumber);
    Serial.println(message.command);
    if (vw_get_message((uint8_t *)&message, (uint8_t *)sizeof(message))) {
      Serial.print("pulse recieved: ");
      Serial.println((uint8_t)sizeof(message));
      Serial.println(sizeof(message));
     //  int command = processResponse((char*)message, 1); //Byte Array Response and Pin Code.
A string is a NULL terminated array of chars. Chars and uint8-ts are the same size. So, sending strings is simple.
Since the library handles all the complexity of sending the data, it is even easier. What have you tried?
The struct members command and clan are NOT strings, by the way. They are pointers that may be made to point to strings.
It is stupid to have struct members and global variables with the same name and different types. Get rid of the String class completely.
The struct member command and the stupid String instance are NOT at all related. Why are you assuming that valuing one has ANY impact on the other?
